Question about Whirlpool LEQ8611L Electric Dryer
Dlg2102w rattles when running comes from the bottom left hand side
My microwave oven door is loose at the bottom left hand side it rattles when I clean it is it safe to use
Yes - just make sure that when you close it it contacts the door switch so unit will operate.
Nov 24, 2015 | Microwave Ovens
Rattling in left earcup
Sounds like you have blown out the cone on the speaker. Have you removed the covering to see if the speaker in that earphone is intact?
Feb 10, 2014 | Bose QuietComfort 15 Headphones
WILL NOT COOL OR MAKE ICE. COMPRESSOR DOES NOT SEEM TO COME ON.
next time send the model number off of the fridge,side by side or bottom freezer model number is in fresh food section,right hand wall up near ceiling or on ceiling,top freezer look on left side wall.if the compressor isn't running most likely you have a bad start device located on the side of compressor,pull out the fridge,unplug it,remove the back outside bottom panel and you'll see the compressor,pop off the metal clip,remove the cover and slide off the start device or overload and relay same thing,then shake the device,if you hear pieces rattling around inside it it's bad,easiest way to check it,if you open the freezer door and you hear the fan blowing around most likely this will be your problem,you might hear the compressor clicking trying to start and it will be hot,also vac out the condenser coil and make sure the condenser fan motor is running good,over heating can take out the start device.good luck.
Jul 05, 2012 | Frigidaire Refrigerators
How do i turn off safe mode on a samsung galaxy ace
Safe mode in Galaxy Ace s5830
To START "Safe Mode" use both hands to Press the Home Key (bottom centre) and then simultaneously Press BOTH the Power (right hand side) key, and the Volume-Up (left-hand side) key. When the Samsung Galaxy logo appears, release the sides' Power and Volume-Up keys but keep the Home key pressed. Safe Mode should come on shortly. SIMPLY DOING THIS SAME KEYING SEQUENCE, WHILE THE PHONE SHOWS "SAFE MODE" IN THE BOTTOM LEFT CORNER OF THE SCREEN, SEEMS TO TURN THAT "SAFE MODE" OFF. Safe Mode prevents Third Party Apps running, apparently.
Apr 18, 2012 | Samsung Lands Phones
My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
Feb 21, 2011 | Watches
I have a bad rattling noise coming from the left hand side crank case any idea ? yamaha 350 banshee year 2005' i have chosen an rd 350 because it doesnt let me choose a banshee
My best guess would be you've lost a magnet from your flywheel or some component from your stator has come loose and is contacting the flywheel. Pulling the left hand cover and have a look...
Take care.
Dec 09, 2010 | Yamaha RD 350 Motorcycles
I have a LG dryer dle5977w and it has started making a rattling noise it is coming from the bottom left side by the lint fan does any one out there have a idea of what it might be
May be a small sock or dryer sheet caught in the blower wheel.
Remove filter and use a flashlight to see down the filter housing. You may be able to see item.
Rotate the drum each way by hand to help see item.
Remove with hooked wire hanger.
You may need a service call to remove object.
Jan 04, 2010 | LG DLE5977 Electric Dryer
Rattling noise coming from the driver side of the car when I drove over 40 miles per hour.
It sounds like 1 of 2 problems but to start with jack up the drivers side rear of car and block front wheels with 2 blocks of wood or 2 bricks , put a stand under chassis and then your safe to work.
Release hand brake and spin rear wheels ..and then hold 1 hand bottom and top and try to shake the wheel.. any movement means worn bearings ..any noise when spinning means worn wheel bearings..If ok
get under the car and bang the exhaust all along and if the rattle comes when you get to the muffler you have you answer.
Let me know how you get on . RON
Nov 11, 2009 | 2001 Toyota Camry Solara
Warning light
HELLO MATE
IVE GOT THE MANUAL AND THAT LIGHT IS YA COOLANT LEVEL IS LOW TOP UP WITH COOLANT RUN FOR 5 MINS SWITCH OFF WAIT A COUPLE MINS THEN START AGAIN
STEVE
Jun 21, 2008 | 1999 BMW 318 ti
Water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Nov 30, 2007 | Zanussi FJS1225W Front Load Washer
Whirlpool LEQ8611L Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
