Question about Kenmore Elite 45986 Front Load Washer
Tere is a small tear in the rubber gasket at the bottom of the door. The wire ring also came loose. Where does the wire ring fit?
  • jwtetu Jan 02, 2011
    Now that I have that small tear in the rubber gasket will I need to replace it? It is about the size of a ragged garbanzo bean.
  • 2,382 Answers
Hi, is it a metal wire connected at bottom with a 2-3inch spring? If it is so, it secures the "bellow to the front lip of the machine. You will need to stretch it over the front "bellow lip after installing the "bellow"
Posted on Jan 02, 2011
  • Tunde Autos
    Tunde Autos Jan 02, 2011
    Yes of course, you have to replace it....
Front door rubber seal
Fairly easy to do. It is held on with 2 wire rings, one on the outside edge of the seal when you open the door and when that is removed there is another one holding it to the outer drum. Removal of the lid may also help with removal of the inner ring. When refitting you press the lip of the seal over the outer drum edge and fit the retaining ring back and then do the same on the front where the door meets the seal. Just make sure the small drain holes in the seal are located at the bottom, best to look at the old one to see how it's fitted before you remove it.
Dec 27, 2012 | Electrolux Washing Machines
I have water leak out of our front loader, it leaks out rite in the middle from the bottom of the door. I am not sure if it is from the small hole in the door or if it because of a bad seal. The rubber...
the wire ring just keeps the seal in place,, make sure the bottom of the door glass is clean,, if so look at the seal and see if it is pushed in alittle around the bottom,,you can take a hair dryer and heat it up while pulling it back out ,, ( just the lip part) if that doesnt work you will need to replace the whole gasket
Jan 24, 2011 | LG WM-2277HW Front Load Washer
Water has leaked from bottom
do you mean from the bottom of door? if so open door and run your fingers around the rubber gasket to see if there is any forign matter or rips, and check the small drain hole on the inside bottom of gasket, if there is a tear you could repair with a bicycle innertube repair patch
Nov 08, 2010 | LG WM-2277HW Front Load Washer
I opened it one day and there was a large wire ring inside - this ring obviously as something to do with the gasket, as the washer leaks like a sieve unless I painstakingly fit it inside the outer rim of...
If you are referring to a wire hoop with a small spring at one end, this is called the outer bellow clamp. This clamp holds the door bellow (gray rubber seal in place) around the perimeter of the door opening. If the spring is missing or worn, you need to replace it. The part number is 8182211 and costs about $5. You can purchase parts at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites have illustrated parts listings to show you how the washer is assembled. If you need guidance on how to reinsert the bellow clamp, skip down to step 12 in the following link:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Make sure the door bellow is fitting properly all the way around the door frame opening. Then insert the clamp in the groove where the rubber fits over the frame. If you're installing it correctly, the clamp will not be visible when you're done. Also, if installed correctly, you should NOT have to reinstall the clamp everytime you do laundry. These clamps usually fit very tight. What can contribute to them coming loose is overloading the washer and having something get caught in the bellow.
If you still need guidance, please post back and let me know. I hope this helps you.
Aug 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Rubber ring ripped
You can buy and fit a new door gasket if you have the required mechanical knowledge
Take the power off , the top off remove the fitting band take off the old gasket and re-assemble in the reverse order
Jan 03, 2010 | GE WSXH208A Front Load Washer
Rubber gasket
Feel around the seal, in the groove behind the seal face. You'll find a spring at the bottom. With a small screwdriver, lever the spring over the seal face. Work the steel ring off. Fold the seal inside the washer. Unplug the washer, Remove the door, and set aside. Locate your panel screws and remove the front, exposing the drum and basket. There are usually additional screws under the dispenser trays too. Disconnect the door lock wires. Locate the other spring/ring assembly on the outer drum, and remove. Orient your new seal properly and reassemble. The only difference on the reassembly is that, when you are putting the rings back on, start 180 degrees from the spring, and work the ring back on until you get to the spring. Carefully lever the spring back over the seal face, being careful not to damage your new seal.
Best regards, --W/D--
Aug 08, 2009 | GE Energy Star WCVH6260F Front Load Washer
Metal ring fell off
If you are talking about a small metal hoop with a spring on one end, it is the outer bellow retaining clamp. The bellow is the rubber door seal. The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If this is not the spring you are talking about, please post back and elaborate a bit more on what the part looks like to see if I can assist you better. (i.e., size, dimension, where you found the part, etc.)
I hope you find this information helpful.
Jun 30, 2009 | GE Energy Star WCVH6260F Front Load Washer
My kenmore he2 plus washer door gasket is loose.
it goes on the groove in the gasket at the door , the side view of the gasket would be a V, it goes right in the middle. make sure the gasket is first snug on the metal frame groove. the spring is very tight, start at top then work down, use a flat screwdriver to pry it in at bottom. it may help to wet the gasket
Apr 27, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite duet 410 metal wire for gasket came off
is it a metal wire connected at bottom with a 2-3inch spring???? is so it secures the "bellow to the front lip of the machine. youlll need to stretch it over the front "bellow lip after installing the "bellow"
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
106 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
