Question about Janome 6019QC Mechanical Sewing Machine
My problem is the thread comes out of needle when it starts to sew.
  • Janome Master
  • 7,365 Answers
Make sure you have a thread tail of 4-6 inches for the top & bottom thread & make sure the thread is pulled behind the needle before you start to sew
Posted on Jan 03, 2011
The thread on my Elnita sewing machine keeps coming out of the needle and won't sew. How can I fix this?
Make sure to pull at least 4-5 inches of thread through the needle eye before beginning to stitch. It will help to also hold the thread tails in your left hand while slowly taking the first few stitches. Another help is to raise the needle to its highest when starting to stitch.
Nov 17, 2017 | Sewing Machines
When sewing thread keeps breaking and comes out of the needle
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
keep longer thread tails before you begin to sew and make sure
the thread tails are pulled behind the needle before you start sewing
Jan 08, 2013 | Yamata Sewing Machines
Needle won't remain threaded
make sure the thread has long thread tails of 4 to 6 inches long
and have the thread tails pulled behind the needle before starting
to sew.
Jan 04, 2013 | Michley Lil Sew Mechanical Sewing Machine
After automatic thread cut the needle comes unthreaded
you need long thread tails, of 3 to 6 inches for the top & bobbin thread so the needle doesn't come unthreaded,
also pull the thread behind the needle before you start to sew
Mar 27, 2012 | Brother PQ1500S Computerized Sewing...
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
The needle will not stay threded as soon as i start to sew the thread comes out of the needle
always keep 3 to 6 inch thread tails for the top & bobbin thread & make sure the thread is pulled behind the needle to the back of the machine & that will keep the thread from coming out of the needle
Sep 04, 2011 | Brother LS-2125 Mechanical Sewing Machine
My consew 230 sewing machine is not holding the thred on the needle. every time i thred the needle and step on the paddle to sew, the needle comes back out unthred, please help.
before starting to sew
1.make sure the top thread & bobbin thread have a thread tail of 3 to 6 inches
2.make sure the thread tails are pulled behind the needle toward the back of the machine
then put the fabric under the presser foot to sew
when your finished with the seam, after the thread is cut from the fabric,, leave the thread tail the same as above before starting to sew again
Jan 22, 2011 | Consew Sewing Machines
The upper loop thread keeps coming out of the eye when I sew
always keep a thread tail of 3-5 inches & keep the thread tail pulled back behind the needles each time you sew,,make sure the thread tail is behind the needles before you start to sew
Nov 27, 2010 | Brother 1034D Mechanical Sewing Machine
My needle does not stay threaded on my Brother Lx 3125 (the top thread) it keeps coming out of the needle while stitching. How can I fix this?
keep a thread tail of 3-5 inches & when you sew make sure the thread is pulled behind the needle each time you sew, even if you have to hold the thread tail with your fingers
Nov 24, 2010 | Brother LX3125 Sewing Machine
Good Morning! The only problem I'm having is, How to put the thread in the needle so that I can get started.
the thread goes into the front of the needle & comes out the back, a thread tail of 3-5 inches is always good with thread pulled behind the needle to the back of the machine
Oct 26, 2010 | White Sewing Sew Cute SC20 Mechanical...
Janome 6019QC Mechanical Sewing Machine Logo
54 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
