Question about Guillemot Hercules DJ Console 4-Mx
RCA output connectors don't give a clear sound on the Hercules 4-MX. Even after updating the drivers. Too much backgroundnoise and hum !!! Does anybody know this problem. USB problem connections ???
  • Guillemot Master
  • 5,603 Answers
Make sure ALL and I do mean ALL interconnected equipments such as this device, amps, players,computers are ALL powered from the same grounded receptacle. Make sure any lighting involving dimmers is kept seperate.
Posted on Jan 03, 2011
HOW TO CONNECT DJ CONSOLE RMX TO DEEJAY TRIM 4&6
The problem may not be your thermostat. The outdoor unit has a refrigerant reversing valve that maybe the problem. This valve changes position pending AC or Heating. The Aux on the thermostat energizes when the outdoor air temp drops below a certain set point set up by the installer or when the thermostat is set to it.
Nov 11, 2013 | Guillemot Hercules DJ Console 4-Mx
Serial number dj console hercules
salve ho perso il numero seriale della mia console posso riaverlo in qualche modo?
Dec 07, 2011 | Guillemot Hercules DJ Console RMX Mixer
How would i connect a Behringer 1002B Xenyx to a hercules mk4 mixer
The main output jacks of the 1002 are PSUEDO balanced so you can use TS to RCA connections from the 1002 to the MK4. It is not hte best design, but it will work... with two cables go from the 1002 main outs to the stereo ins of the MK4.
Sep 19, 2011 | Behringer XENYX 1002B Mixer
Power dont *** on
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Aug 08, 2011 | Fender Squier 4-channel Travel PA...
Intermittant LR output problems Main outputs (XLR
Intermittent problems cn be a real pain to find... BUT I want you to verify your use of the mixer and its connections as one can cause the output drivers to latch up due to ground bounce.
Make sure your outputs go to the power amps AND into balanced inout at the amps... either XLR or TRS connectors.
Make sure that the amps are POWERED from the same receptacle as the mixer... even if you have to run power back to the mixer. If you power the mixer from a different receptacle at the other end of the room, ground bounce of the safety ground MAY exceed the common mode drive of the mixer and cause the output drivers to latch up or even be destroyed!!!
Aug 11, 2010 | Peavey 32fx USB 32 Channel Mixer
I have a djm 400and a pair of active behringer speakers model b2031a an im gettin no output from then what am i doin wrong the leads are male to female in the back of the speakers an obviosly like a phone...
First, we need to get the terminology correct.
The DJM has "PHONO" (RCA) jacks, not "phone jacks" of which the current usage is normally the 1/4 inch diameter.
You would be going INTO the Berhinger 1/4 inch jacks on the back of the speakers since you are not using the three pin XLR connections that are used for balanced lines which the DJM does NOT have.
So you should have RCA plugs to 1/4 inch plug cables. The inputs on the 1/4 inch will take TRS connections. IT IS possible you may need to use an RCA to TRS cable with the signal on the "ring" rather than the "tip" of the connector.
A test of the speakers is to touch the tip of the RCA plug with the speaker on and you should hear a hum.
PLEASE be aware that these speakers are INTENDED for use as studio monitors by the sound man in the booth and NOT for playing loud at a venue for dancers, etc.
Dec 16, 2009 | Pioneer Music
NO sound through the AMP even though the power light comes on
Not a fuse. First thing, to check your speaker (amp unplugged, of course), touch the + and - speaker connections to a 9V battery. If you don't hear a pop sound then your speaker is blown. Thus, no output sound. If speaker is OK, then the output IC is your problem.
Jul 12, 2009 | Music
Yamaha Clavinova CVP-83S NO SOUND OUTPUT
clavinova 83s...comes on but goes off within 20 sec.,sometimes comes on display lights up but no sound or functions?
Apr 01, 2009 | Yamaha Full-Size Keyboard
Guillemot Hercules DJ Console 4-Mx Logo
119 people viewed this question
Top Guillemot Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Guillemot Music Expert? Answer questions, earn points and help others
