I have a Kenmore HE 2 plus washing machine. I washed and old blanket in it and I think it totally fell apart into small pieces and clogged up the machine. I have an F21 message and the machine is locked. What can I do?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
n After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
prese stop twice to clear display
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Jan 02, 2011
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Simson top loader washing machine drum does not spin
Your motor coupling must be worn off. Replace it. It is centered with motor and transmation 2 small plastic pieces
don't wash bed blankets. Or carpets or alike. This is the major problem
Feb 16, 2015 | Washing Machines
Kenmore model 110 blanket fell apart, now it won't spin
check the plastic/rubber connector that connects from motor to transmission it's probably broken.
Apr 27, 2014 | LG WM-2277HW Front Load Washer
I have a Kenmore top loading washer. While moving it into the house, it made a loud sound and a small copper pin fell out of the bottom. Does anyone know how to put this back in place?
That pin is a pin used to move the washer (secure the drum) and is not used when in normal operation. There are 4 total that should be removed. They are stored in little cups on the legs, and likely fell out of the cup.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washed a bathroom rug, which fell apart in the
The little pieces off of the bottom of the rug are clogging up the pump. Clean out pump.
Jan 15, 2010 | Dryers
My Kenmore Elite he5t washing machine isn't draining. My daughter put in a load of old material, and some of it just fell apart when it got wet. We cleaned out the junk trap down by the pump, and that...
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 27, 2009 | Kenmore Elite HE5t Washer
I have a Kenmore HE2 with a hole in the tub.
Any 2 part waterproof epoxy.
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
