Question about Fisher and Paykel Dryers
I need to fit new bearings which fell out and i do not know how they go back in
    Scholar:
  • 170 Answers
It's possible that they are from the wheel rollers that the drum rolls on. If that's the case, you will need to replace the rollers. They are usually sold in pairs at an appliance parts store.
Try turning the drum by hand and see how it turns or sounds and then post back what you find.
Posted on Jul 09, 2008
How to remove the wheel bearing from and integra 97
Undo the brake caliper remove the big nut and pin that holds the disc on ,then slide the disc off the axle and remove bearings and seal ,knock out the old cup,s with a pin punch and fit new ones,pack new bearings with grease and fit back to axle adjust bearings to correct tension re-pin the nut.
Sep 30, 2016 | 1997 Acura Integra excluding Type R Models...
How do you install a split hex flange bearing?
The split hex flange bearing fits on the front axel assembly of the Troy-Bilt self propelled mower. To install it, remove the front wheel to see if you can access the old bearing and pop it out of its position on the assembly. If you cannot reach it, you'll may to detach the axel assembly from the mower itself. You'll find the old bearing behind the plate that attaches to the mower frame. You may have to remove a nut that holds it in place, then remove the flange bearing itself. Put in the new one and reverse the procedure.
All that being said, it's hard understand how you would know that the split hex flange bearing needs replacing if you haven't already disassembled the axel assembly to check its condition. If the bearing, itself, just fell out and someone told you what it was, he should know how to replace it.
This bearing should rarely need replacing. If it does or if it just fell out then you likely have much bigger problems than just replacing it.
Jul 26, 2014 | Troy Bilt 5.5hp Self Propelled Mower
CARBURATOR OF NISSAN 1400 BAKKIE
the ball bearing will be a non return valve for the accelerator pump. When the pump is moved to suck in fuel from the bowl it lifts of the seat and when the pump is pressed down the force of the fuel closes it off and the fuel is squirted in to the manifold.
Jan 19, 2014 | Nissan Cars & Trucks
Put a ball bearing back in a high pressure oil pump
If it fell out then it can't do it's job which is to regulate the pressure within the pump and is "shot."
Aug 27, 2012 | Ford Cars & Trucks
Right wheel fell off how do I put it back together need a schematic
if your wheel fell off there is no shematic that i know of however check to see if the studs are stripped if so pull the wheel ( POP-OFF THE BEARING CAP WITH A FLATHEAD SCREWDRIVER) unscrew thew wheel nut and pull the wheel (being careful not to drop the bearings on the ground ) then with an old nut or board (2 by 4) or something similar so you don't flare the stud so that it wont go through the hole. drive studs out and replace (fairly cheap). when you put the new studs in make sure that the teeth on the back of the hub line up with the teeth on the studs before you drive them in.if the whole fell off make sure that the threads on the spline (shaft) are not damaged. if so repair the threads and get new bearings . ( bearings only go in one way) and nut and cotter pin. (if you don't know that the race is any good take the hub to the auto parts store and ask the attendant at the counter) when reassembling do not over tighten the wheel nut and BE SURE TO PUT THE COTTER PIN IN AND BEND 1 PRONG BACK.
Sep 08, 2010 | 1987 Ford Ranger
Left rear wheel bearing
Hi
Quite easy !
Slacken your wheel nuts, Jack up the car, support on an axle stand, remove the wheel.
Knock off the little domed dust cap with a screwdriver.
Remove the split pin, and undo the nut.
The drum should now pull off if you remember to let off the hand brake !
Pull out the inner seal and the bearing race will fall out, also remove the outer bearing race.
Now you have to knock out the 2 bearing tracks from the drum hub.
Clean up the drum, carefully tap in the 2 new bearing tracks with a socket, and then grease the bearing races liberally with LM bearing grease.
Fit the bearing races to the drum, along with the new seal, and refit the drum, tighten the castle nut, then just back it off slightly, and fit new split pin, and then the dust cap.
Back on with the wheel, and give it a spin, and check for play by holding tyre, top and bottom.
Good Luck !
Let me know if you have any problems !
Give me a FixYa Rating Please.......Nearly a Guru !
John.
Feb 05, 2009 | 1995 Geo Metro
I have a hotpoint first edition 800 wm 51 can you tell me is it east to change the bearing in the drum
It is a fairly straight forward repair to do, if you know what you are doing.
The bearing comes as a bearing kit, consisting of 2 bearings and a shaft seal, yuo will also need a new container front seal, and depending on how badly the bearings are worn, you may need to fit a new drum shaft as well.
Again depending on how badly the bearings are worn, they can cause wear in the bearing housing, this being the case, then you would have to fit a new outer tub.assy complete,
This then puts it beyond economical repair.
Obviously , you will not know what is req'd until it is stripped down.
Plz rate my comments towards providing a solution to your problem.
Thankyou.
Jan 25, 2009 | Washing Machines
Tecnik oven inner glass has fell out. how do i re-fit it
i have never managed to be able to reglue this type of door. you are faced with buying a new part
Sep 30, 2008 | Tecnik TKC8525 Double Oven
Open Questions:
Dryers Logo
52 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
