Question about Linksys WRT160N Wireless Router
My router shows connected but no internet access.
  • Jeffrey Groves
    Jeffrey Groves Jan 02, 2011
    Is this the first time that you're trying to use your WRT160N?
  • 442 Answers
Please try connecting the DSL / Cable modem directly to your computer and check if the network works fine, it works fine then power down the wire router and then restart it again and check.
Posted on Jan 02, 2011
  • 29 Answers
SOURCE: cisco 871w router
Is this router brand new sound like it could be a bad router. The wan port could be going bad. I have had similar problem like this before and took days for me to figure out.
Posted on Jan 15, 2009
SOURCE: cannot access internet with wireless router connected
powercycle the belkin router and modem and computer..
Posted on Jan 18, 2009
  • 86 Answers
SOURCE: F5D7231-4 stopped connecting to Internet via downstream router
Why did you change it from dynamic to static? My suggestion would be to put it back to dynamic and let it grab a good ip address from the gateway. The other option is to contact whoever managed the network at your apartment and see what they will charge you for a static IP address.
Posted on Jun 03, 2009
kakee
  • 1269 Answers
SOURCE: can connect to router, but router wont connect to internet
The router needs to be configured manually. Follow the steps below.
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing).
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Posted on Oct 06, 2009
Testimonial: "Ah!Brilliant! This was fantastic instructions on how to fix such a really simple problem I had no idea I was having! "
  • 4044 Answers
SOURCE: belkin router F5D8638-4 laptop connects but no internet access
Make sure you entered the same key exactly the same way in both the router and the computer. Also, make sure you have selected a Security protocol that is supported by the computer. Some versions of Windows do not support WPA. XP supports it but really doesn't like to auto detect it. If it's a HP laptop make sure you are using a communications channel other than 6. Some routers give you an option to select the channel HP computers don't like working with channel 6.
Posted on Jul 28, 2010
Why does my TL-MR3020 Portable Wireless N Router Keeping dropping out a few moments after appearing to be connected to the internet
Why have you two routers connected to the same network?
1. TL-MR3020 Portable Wireless N Router
2. Three ZTE MF730M dongle (router).
The problem is the router does not know which route to choose, so remove one of them and it should stop dropping out.
Nov 29, 2014 | TP-Link Technologies TP-Link TL-MR3020...
After installing belkin wireless g desktop card icon shows not connected but signal icon shows good connection
It would appear that your computer can access the connection to the router, but you have not logged onto the ISP so you don't have internet access.
You need to click on the connection that is available and enter the password/passkey to access the router. All routers should be secured with some kind of password so that only authorized people can access them.
Apr 15, 2011 | Computers & Internet
Laptop shows no internet access all of a sudden although shows router connected for local access. LED display on internet port of router flickering
plug a computer into it, launch a browser and access 192.168.1.1 This will get you into the router itself i would reset it to default and then reprogram it
Apr 01, 2010 | Linksys Wireless-G WRT54G Router
My router does not recognize the internet when I am setting it up, however, I can still access the internet through wireless connections that go through the router. I go through the setup process, and the...
I think you are trying to set up router using the Cd program or Linksys Easy Link advisor program. This program has some bugs. It will show you that you are not connected to the router but you are online. Some times it will show you that there are some other people connected to your wireless network but there are not.
So if you are trying to run that program then you don't need to use that program. Even if you call the Linksys tech support number , no one will give you proper answer for that.
you can set up the router manually without the CD.
Click Here for more information about the routers and the network
Jan 14, 2010 | Linksys Wireless-G WRT54G Router
Two PC's,no access to internet upon PC connected by Adaptor.
solution 1:Reset the new password for accessing for internet.
solution 2:check with adapter.plug out and plug in the adapter(and also antenna too )
Feb 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot access internet with wireless router connected
Jan 17, 2009 | NetGear WGR614 Wireless Router
No internet connection through routers (broadband AND wireless)
Try to disable any firewalls on your computer. If you already have internet details showing, there's something blocking your connection which is possibly a firewall. Turn off the Windows firewall as well as Norton, Mcafe, Zone Alarm and the like if you have one.
Nov 01, 2008 | D-Link AirPlus DI-524 Wireless Router
The network is working but I can't get the internet
If the internet is not working first thing to check here is the internet connection from your modem without the router, make sure that your computer can access the internet when computer is connected directly to modem, if no internet without the router you need to contact your ISP for that, but if there's internet without the router you need to reset and reconfigure the router.....if you have the setup CD of the router just run that to reconfigure it back.........
Aug 12, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
Netgear Wireless Router WGR614v6
so chitodel click on start button
then CONTROL PANEL>NETWORK CONNECTIONS> right click WIRLESS CONNECTION>PROPERTIES>in GENERAL tab click on INTERNET PROTOCOL>PROPERTIES and then click OBTAIN AN IP ADDRESS & OBTAIN DNS SERVER ADDRESS AT LAST CLICK O.K. this will help u try it now..........................
GOOD LUCK.
Feb 06, 2008 | NetGear WGR614 Wireless Router
Linksys WRT160N Wireless Router  Logo
789 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
