Question about Apple iTunes
ITunes occasionally dumps my entire library, playlists, apps, everything and when I open iTunes I get the bare-bones program. Also, the iTunes Library Extras & iTunes Library Genius files are in my Recycle bin! When I restore the 2 files, they simply get binned again when I open iTunes again. Help, this is doing my head in..... It has happened 3 times now in the last couple of months and I can't see a pattern to help me work out what's happening to make this wierdness happen. Cheers
the_fire
  • 432 Answers
SOURCE: Playlists & thousand songs dissappeared from itunes
if you synch it yes it will wipe it out - you can get software to back your ipod back to your computer so I would personally delete all the play lists and re do it. your music will be in my documents --> music --> itunes so you can re add it that way and re sort the playlists.
If its on mac os then it will be under your music folder ( macintosh hd --> users --> your username --> music --> iTunes
It may be that your itunes library file may have gotten corrupted so once you have gotten it sorted out close down itunes and go back into your music folder and itunes folder and make a backup copy of your itunes library files.
Assuming your not moving your music files around in side of the music or itunes folder it should be fine.
Posted on Apr 10, 2009
  • 144 Answers
SOURCE: Itunes library problem, itunes not opening
just uninstall the software and go to www.itunes.com and and download it. it automaticaly should download the one you need for your computer
Posted on Jun 05, 2009
SOURCE: The iTunes Library file is locked, on a locked
1. Open Finder. Goto Music > iTunes > and locate the following files.
iTunes Music Library.xml
iTunes Library.itl
2. For each file:
Right click on each file.
Click on Get Info
Under the Sharing & Permissions Tab: Make all the Privileges 'Read & Write'.
Close the Get Info box
Open iTunes again.
This worked for me on Snow Leopard.
Posted on Apr 23, 2010
  • 38 Answers
SOURCE: When trying to open iTunes, I get the following
Hello wjewell154 for some reason some of your registry's were deleted from your computer. the solution to this problem is to uninstall your current Itunes software and reinstall itunes.
NOTE:uninstalling iTunes will not delete any preferences, playlists, or content; thing of what you are doing as a manuel upgrade
If you are running Windows Vista/7 goto the Start menu select "Control Panel" from the right column from that menu, select "programs and features" now find iTunes in that list and right click from the right click menu, select the bold option "Uninstall" your uninstall program will gather information about the program and then it will uninstall now click here and it will guide you to the apple website to reinstall iTunes 10
please rate :-)
Posted on Nov 16, 2010
drifterK
  • 4924 Answers
SOURCE: I'm running windows vista, and
http://www.tidysongs.com/
I will go for putting things right in the Itunes ..and after that sync again and this way you will no longer have the duplicates in ipod also ..
for to get rid of the duplicates use the software I just linked...they say it works great wit itunes..and this will clean your library of any duplicates...and after that when you will sync.you will have only the good stuff in it ..
You may even delete all things in ipod..just to be sure it do not mess with the sync..and reload the duplicates...by sync-ing the itunes with your ipod instead of the other way around ..
So ..first make a sync .to be sure you have all the files in itunes..even if you have them in double ..
after that use the software to get rid of the duplicates..
after that format the ipod ..and remove all files..
Make a sync again ..and have only one instance of the files ...
If you have a great deal of songs on it ..and it is a lost of time to sync it again ..try t see if the software works on the ipod also ...I am not sure but only about itunes..
Posted on Jan 12, 2011
Transfer playlist from Itunes to Ipod Nano
Open iTunes and plug in your iPod. On the left sidebar there should be your iPod name (If you can't find the sidebar, go to iTunes menu bar, under View, select Show Sidebar), go to your iTunes playlist and drag the songs you want to your iPod. For all of the songs, go to your iPod music library, even if you don't have songs, and on the bottom there should be a blue-ish bar. There might be a box saying "Autofill from iTunes library" click that ONLY if you want ALL songs from your iTunes to your iPod.
If you want to know how to put video or DVD movie onto iPod, I think this step by step guide would help you.
http://www.dvdintoipod.com/how-to-convert-dvd-video-to-ipod.html
Hope it helps. Feel free to email me if you need further help.
Dec 10, 2013 | Apple iPod nano 3rd Generation
Tip
How to Add iPod Playlist to iTunes?
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Are you an IPod greenhand or new user to iPod? Are you annoyed with how to transfer iPod playlist to iTunes? So, how do you get iPod playlist to iTunes? Factually speaking, it's not difficult to do it. All that we what we have to do is to make sure your iPod connect to your iTunes and that you follow the instructions below.
But, just like everything surrounding the App Store, there is always an "App for that". iPod to computer is one of those apps that provide you a fast way to transfer iPod playlist to iTunes.
The iTunes program servers as both a media player and a database for the content you've added to it. The program window lists your songs and videos so you can see what you have, but the actual files themselves are stored elsewhere. In the default location, your files are nestled inside subfolders within the iTunes program folder on your hard drive.
If you're like a lot of iPod listeners, one of your favorite things to do is make up new playlists. You might spend hours each week working on making up new lists for different occasions. You've probably got a list for doing homework or work, a list for working out, a list for driving in the car, and a list for a romantic date. Having all these playlists can be a lot of fun, and sometimes making them can be a little addicting, too.
This is why many people love the on-the-go playlist making application on their iPods. With this application, you can put any song on your iPod into an impromptu playlist. Maybe you want a brand new list to express your mood for today. Maybe you're just on a roll with discovering new music and are making a fantastic playlist for a friend. Either way, making these lists can be fun and interesting.
The problem, however, is that you can't save or label on-the-go playlists. If you leave them on your iPod, they'll just be named on-the-go and called by the order in which you made them. You won't be able to rearrange them or fine tune your playlist making skills like you can when you're actually making a list in iTunes.
If your iPod is broken and all you want to do is that transfer all the files to iTunes? How can you to transfer then? Maybe you are worried about these problems and think that it is hard to do it because the restrictions by apple. Here I want to say it is easy now as longs as to use a software to help us and then we can get what we want easily.
Here I want to choose Cucusoft iPod Transfer according to the long-term good test.
Before you run our program, please be sure you have installed iTunes on your computer, and you can manage your ipod device with no problem.
Step 1. First connect your iPod to your computer via USB cable. Then install and run iPod Transfer. After done, the playlist will be shown on the main interface as below. All the playlists and other files will be shown on Cucusoft transfer below.
Step 2. Copy the playlist and transfer into iTunes library from iPod.
Step 3. Click the "Export" button and start to copy ipod playlist to itunes library right now. Choose Export to iTunes and OK.
Now you have successfully copied ipod playlist to itunes!
on Sep 25, 2010 | Computers & Internet
I want to make a copy of my itunes library from my Windows PC to a 1TB Seagate external hard drive
Open up Itunes in the top left hand corner select file from the drop down list select library then you will have options to back up to disc organise library export library import playlist and export playlist
open Itunes in the top left hand corner select file from the drop down list you will see Library click to open then you should see back up to disk then more options back up entire library to disk
other programs you might use to back up your Library
http://download.cnet.com/sharepod/3000-2141_4-10794489.html Back up and restore your iPod or copy music and videos to and from the device. http://download.cnet.com/podtrans/3000-18546_4-75733600.html Transfer music to iPod or copy iPod music to your computer. Freeware
Hope this helps.
Jan 03, 2013 | Microsoft Windows Vista Home Premium for...
Itunes wont open
A corrupt iTunes library prevents the iTunes program from opening and prevents Apple device synchronization. According to Apple, the iTunes library must be rebuilt, which resets the library and removes the current content in the media manager. Back up your media prior to recreating the library, as the recreating process erases all content and your Apple device will synchronize with the blank, recreated library and erase the device's information.
Insert the DVD-RW disc into the computer's DVD-RW drive, and open iTunes. Click "File," "Library" and "Backup to Disc." Select the iTunes library and playlist backup and click "Next." Eject the disc after the backup completes, and close out of iTunes. Move "iTunes Music Library.xml" from your iTunes folder to the desktop. Right-click "iTunes Library" and click "Delete." Launch iTunes and click "File," "Library" and "Import Playlist." Locate and double-click the iTunes Music Library.xml file. Insert the burned disc into the DVD-RW drive and click "Restore." or
Fix iTunes if It Won't Open on Your Computer b> You've clicked and clicked and clicked some more, but iTunes just refuses to launch. A non responsive program is frustrating to any computer user, but especially if all you want to do is listen to some music or download a new album. If iTunes isn't opening, there are many possible causes for this error. None of these fixes will affect your current music collection. Though you may need to tweak or reinstall some software, your MP3s will stay right where they are.
Confirm that your Apple device is connected securely to your computer. If you are not trying to access iTunes via an Apple device, or if your device is connected correctly, continue to step two. Configure your firewall to allow iTunes to connect to the Internet. Many firewalls block software programs' ability to get online as a security precaution. This is because some spyware and malware is designed to transmit personal data from your computer. Making iTunes a trusted program within your firewall software is necessary for it to function properly. Create a new iTunes library file. An unstable or corrupted library file can cause iTunes to suddenly quit or not open at all. Recreating a library file is a lengthy process that depends heavily on the operating system you are using. See the iTunes Support page under. http://support.apple.com/kb/HT1451 Reinstall iTunes on your computer. If no other troubleshooting steps are successful, then the fastest way to solve the problem is to start from scratch. Hope this helps.
b>
Dec 26, 2012 | Gateway MX Computers & Internet
I have 4 ipods and want to use them on itunes with different playlist
you will need to download and have 4 separate itunes installed either on one or more computers if you want to have separate lists of playlists othewise you you will have to have all playlists on one installed itunes
never select update to another version of itunes
as i have done previously you will lose all songs loaded and you will have to load all music on again to sync your ipod
unless you back your music up to a disk/s
hope this helps you
Mar 22, 2012 | Apple iPod touch
How to transfer playlist from itunes to ipod model a1236 4gb
As is known, iTunes helps to sync media files and apps. when users are about to sync music to their iPod, they'll find the option of syncing playlist. When the users check the playlist to sync, they will sync the whole playlist to their iPod.
  1. Connect your iPod to computer, and launch iTunes if it doesn't open automatically. As is shown, all the playlists on iTunes are on the left side.
  2. Then, click "iPod nano" on the top of iTunes. Some of you may prefer the old look of the iTunes. If so, go to the View menu and select Show Sidebar to show the left side of the window that displays all media libraries.
  3. Click Music, then choose "Sync Music", "Selected playlists, artists, albums, and genres" and target playlist > Click "Apply" below to transfer playlist from iTunes to iPod.
transfer-playlist-from-itunes-ipod-model-oxaxc0rwhkhzilrwacqreyis-4-0.jpg Please note that if you have saved playlist(s) in your iPod, you'll need to check these playlist(s) as well in case that iTunes erase the playlists during the sync.
http://www.leawo.org/tutorial/transfer-playlist-to-iphone-6siphone-6s-plus.html
Mar 02, 2012 | Apple iPod nano
I am having problems sorting my music out on my ipod and syncing music from PC to ipod. I think there was a disc when I first brought ipod but have since moved, brought new pc and left disc back in other...
open up Itunes in the top left hand corner select file from the drop down list select library then you will have options toback up to disc organise library export library import playlist and export playlist
open Itunes in the top left hand corner select file from thdrop down list you will see Library click to open then you should see back up to disk then more options back up entire library to disk
also here are a couple of programs that might help
http://download.cnet.com/iPod-Folder/3000-18545_4-54014.html
  • Detects the iPod music structure
  • Calculate the iPod music file size
  • Counts folders and displays folder size
  • Copy all songs into a folder (on any volume)
What
Jun 06, 2011 | Computers & Internet
How do i download songs from my pc itunes to my iphone 4
There are 2 ways,
1) sync music to your iphone through itunes by selecting the music tab on itunes and select the song you want to sync
2) sync by manually dragging your music to the iphone icon in itunes. you will need to click off the box "manually sync files to iphone" at the bottom of itunes
Nov 21, 2010 | Apple iPhone 3G
How do u change the songs on an iPod Shuffle?
You can set iTunes to transfer a selection of songs from your entire music library or from a specific playlist. Connect the iPod shuffle to your computer and select it from the iTunes Source list. Select the source from which iTunes will transfer to the iPod. In the
Aug 26, 2010 | Apple iPod shuffle MP3 Player
Wiped my entire music library.
You're ok as long as the music is still on your iPod.
There are a number of apps which will help you recover your music from your iPod to your PC.
The most advanced ones will allow you tu recover absolutely everything (playlists, playcounts, meta data, ratings, videos, etc.)
I personally prefer:
CopyTrans (http://www.copytrans.net) : $19.99
or
SharePod (http://www.getsharepod.com/) : Free
Full comparison of solutions here:
http://en.wikipedia.org/wiki/Comparison_of_iPod_managers
Jul 16, 2009 | Apple Audio Players & Recorders
Apple iTunes Logo
87 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
