Question about Panasonic PT-44LCX65 Television
Light spot on screen - Panasonic PT-44LCX65 Television
    Brigadier General:
  • 8,909 Answers
That could be just a finger mark. Try cleaning with a soft cloth and mild washing up water.
If the mark is due to damage on the screen, it rarely polishes out and usually gets worse with polishing.
Hope you get it off.
Posted on Jan 02, 2011
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
Spots all over screen
We will presume you have a DLP set that uses a lamp of some sort(no brand or model indicated here).
spots or dead pixels are usually a damaged optical light engine--there are ones where more and more appear.
A faint possible reason is dust is inside the optical light engine--seen it a few times but the spots are usually golf ball in size----high pressure air applied to the vents in the engine with set on in a dark room usually clears that up.
Jun 12, 2012 | Televison & Video
My screen is showing white spots (pixel size) How do get rid of them
On a WS-73735 the white spots usually mean a failing or damaged optical light engine.
It is a major part----Google the model number with "problems" or "light engine" etc.
Jun 10, 2012 | Televison & Video
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
PT52LCX15 sun spot on screen. Is it an easy
Panasonic servicer will have an eprom tool that connects inside the set. It removes spots. After the repair if he calls Panasonic tech line and says he removed fuzzy spots Panasonic will pay for the service. If that does not work then light engine needs replaced.
Nov 24, 2009 | Televison & Video
I have pink spots on my tv screen. do you know
you most likely have a light engine problem ocouring causing the pink spots
they usualy have to be replaced with a remanufactured light engine you might see if you got a extended warranty on the unit as this can be a tad expensive
Oct 30, 2009 | Panasonic PT-44LCX65 Television
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Spots on screen
Spots on screen do not automatically mean you need to replace the light engine. It depends on the brand. Panasonics can reset the eeprom. Samsung can replace the DLP chip. Hitachi needs a light engine replaced.
Nov 26, 2008 | Televison & Video
Gray spots on screen on a JVC HDILA model HD 56G 787
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Black/GREY screen with light spots screen
Try reinstalling the gpu driver. If the problem still persists, the screen may be going out.
Apr 17, 2008 | HP Pavilion dv9000t 17" Notebook Laptop PC...
Panasonic PT-44LCX65 Television Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
