Question about Cameras
Casio Exilim S5 camera flash issue. Flash setting is stuck in the "off" mode. Can take photos without the flash, but cannot change the flash setting to "on" or "auto".
  • bamacy111 Jan 03, 2011
    There's no LED on the back relative to the flash as far as I can tell. There is a menu indicator, however, which does not change when I attempt to change the setting of the flash from "off" to "auto" or "on"
  • Cameras Master
  • 4,924 Answers
There are more possibilities...first is that the settings can not be changed cause the flash is dead and the lack of contact make this not be recognized on...
Second it may be a firmware malfunction and in this case you have to download the firmware update and install it in the camera..procedure is explain at download on the support site ..
The last possibility is that the camera is set on a shooting mode that do not allow /require the the flash ...for example bright light ..mode..Check it and put it in normal mode and after that enable the flash ..or ...try to see in the main menu the reset to factory settings and engage it ...This should make all function work if there are no physical damages..
Posted on Jan 03, 2011
  • Cameras Master
  • 19,396 Answers
Hi.
First ensure that battery is fully charged.
Check the operation lamp(refer to manual, it is located at back side). If the led is yellow, then the flash is charging. If the flash never gets charged you will need to have the flash capacitor replaced.
You can get a quote on repair calling Casio. You can also get a quote from a third party repair service here:Repair.
Regards.
Ginko.
Posted on Jan 02, 2011
I have sony cybershot mega pixcel,when i take picture without flash it got blurry. what's it solution is it any camera problem or any settings?
Check if the camera is in macro mode. It's indicated by a small flower-like notification on your LCD. Perhaps the camera goes back to normal mode automatically when you turn on the your flash.
Aug 26, 2011 | Casio EXILIM Digital Camera
My flash won't turn on, no matter what I do. And without the flash, my pictures are horrible. Help please?? I have the EX-S5 and I've only had it about a year.
Possible failure of the flash unit or the trigger to the unit from the main controller unit of the camera. Since you are not able to switch on the flash manually the fault can be due to either of these sections , a possible electronic failure within the camera.
You will need some expertise to open and check for the power to the flash, if so the flash unit is faulty.
If not the controller unit is faulty..
Feb 25, 2011 | Casio Exilim EX-S5 Digital Camera
Flash setting is stuck on "flash off" and wont change
The flash settings don't work in some modes...what mode do you have the camera set to?
Jun 26, 2010 | Casio Exilim EX-S5 Digital Camera
How do I turn the flash off?
  1. Press 'down' key (which is located below SET button) once.
  2. Use 'left' or 'right' key to select mode with crossed flash symbol in a circle ('flash off' mode).
  3. Press SET button to submit selected mode
  4. Make photos
Jun 19, 2010 | Casio EXILIM EX-Z1000 Digital Camera
Casio EX-S5 camera, how do you set timer so I can be in pix
In the REC mode, press [MENU], select the REC tab, then select "Self-timer."
Dec 20, 2009 | Casio Exilim EX-S5 Digital Camera
I have a casio exilim EX-Z60 the mians battery charger flashes constantly red when I place in my battery, but does not charge the battery, can you advise please
I have a casio exilim ex-z60 which I bought 2 yrs ago. I've had problems with my flash going off each time I turned on and off the camera, about 5 months ago. Now the flash does not work. Need help on how to restore the flash bulb or battery in the camera.
Jul 28, 2008 | Casio Exilim EX-Z57 Digital Camera
Flash not working
Sounds like a burn out, or a bad lamp.  The flash is subjected to a huge jolt of electricity each time it fires, and breaks easily, especially when hot.   If you are taking many flash photos, you should stop after 15 or so, to let the flash unit cool.
Good luck with Casio, if you are still under warranty.  It will probably mean mailing them the camera for fixing, or replacing.  Sometimes you can take it back to where you bought it for repair.
Nov 28, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
