Question about Palm Tungsten E2 Handheld
My battery wont turn off i turn it off and 10 seconds later it comes back on. what do i do
  • Palm Expert
  • 2,973 Answers
The power on switch has gone bad and that is the reason why the HH comes back on after sometime. It seems to be stuck in pressed position and hence needs to be replaced. Please have it replaced from the nearest Palm Service center.
Posted on Jan 02, 2011
Touchpad wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 25, 2012 | HP Touch Pad 16GB Internet Tablet
I have trouble starting my van and later on the check light came on (P1607). The car can no longer start but sometimes when I fiddle with the battery it would start up again and when it does it runs fine....
P1607 means "powertrain control module (PCM) internal circuit malfunction". According to the factory service manual, a low battery condition can cause this. This code can also pop up after the battery has been jump started.
You need to reset the PCM. To do this, turn the ignition switch off. Remove the No. 13 fuse (7.5Amp) from the passenger's under dash fuse/relay box for at least 10 seconds. Put the fuse back in. That should complete the reset.
Now to check again for the code: turn the ignition switch to on (not start.) Wait 30 seconds. If the check engine light stays OFF, turn the ignition switch off and wait 10 seconds. Turn the ignition switch back to on (not start). Wait 10 seconds. If the check engine light stays OFF, you had an intermittent fault and it has now been reset--everything is fine. If the check engine light comes back on during these checks, have the code that set read out. If the code is P1607 again, then you may have to have the PCM tested at the dealership for an internal fault.
Feb 04, 2011 | 2002 Honda Odyssey
I have a 2001 saturn sw and replace the ign and the secuirty light flashs and eng will not crank.i dissconnected the battery over night and still the same. thanks steve
Hello: Try this procedure, Turn key on attempt to start engine leave key on, the security light should be blinking, wait 10 minutes. The security light should be off. Turn key off for 10 seconds, turn key back on (DO NOT ATTEMPT TO START) wait another 10 minutes. Turn key off for 10 seconds. Do the procedure again as in step 2. At the end of the third time turn key off then ten seconds later attempt to start the car. It should start.
Nov 25, 2010 | 2001 Saturn SL
My hp notebook just shut off,wont come back on
Sounds like a burnt out capacitor. Either on motherboard or power supply.
You can try taking out battery, press and hold power button for 5 seconds, put back in and try to turn on. If it doesn't turn on, then I'm afraid motherboard is bad or memory card is faulty
Nov 11, 2009 | HP Pavilion dv2610us Notebook
My mom can not turn on here laptop
Hi:
You might want to resubmit your problem, with more details, but some general things to check are:
1) Is the laptop battery charged, or is the laptop plugged in ?
2) Remove the battery, unplug the AC Adapter, then hold the power switch down for 10 seconds, then put the battery back in , connect the AC Adapter and see if it turns on
3) Remove the battery, unplug AC adapter, hold power button down for 10 seconds, and then plug in the AC adapter, see if it turns on.
If all of the above fails to help, You most likely need to take the laptop into a shop for further troubleshooting.
Oct 30, 2009 | Computers & Internet
When i press power, lights and fans come on for 2 seconds, shut sompletely off, then about 10 seconds later, they do the same thing, over and over again, but the computer will not turn on/boot
take out the battery and the mains, hold the on button for 30 sec's, plug the mains back in while holding the on button and it shud *** on... put battery back in when fully loaded up....
Happened to a friends hp laptop and i found this simple fix, should work...
Gerard
Jul 29, 2009 | HP Pavilion DV6700T Notebook
My Maxent turns off when it comes back on it has dark colors.
goto maxentuse.com, open user manual and look under troubleshooter.
May 01, 2008 | Maxent MX-42EPM20 42 in. Plasma EDTV
I TURNED MY COMPUTER OFF AND IT WONT TURN BACK ON
is it out of batteries? also, check if the battery is loose. Good luck!
Apr 23, 2007 | IBM ThinkPad R50e Notebook
Palm Tungsten E2 Handheld Logo
164 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
