TV wont turn on and all plugs are plugged in - Televison & Video
    Problem Solver:
  • 4 Answers
Most problems like you descripe are the power button on the tv is switched off, or the power cable is not getting connection from the mains, make sure the cable is tight to the TV and the wall.
If that dosent work then there is a possibility that you need to get an expert to open your TV.
Posted on Jan 02, 2011
Why wont my lg 50 plasma tv turn
Perhaps replace your power cord. Borrow power cord from repair shop. If it works it's the cord. Also if the TV is plugged into power bar make sure the power bar hasn't been inadvertently turned off.
Oct 07, 2015 | LG Televison & Video
Tv will not turn on green light comes on then flashing red light it wont turn on
Parents Sony flat screen did the Same thing. I pulled the plug on the back of the TV for a minute plugged back in wha la! Problem solved
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
Aug 21, 2012 | Polaroid TLX-01511C LCD TV
My silo tv wont turn on
Case of leaky/dry/short capacitors and also dry solders.
Aug 11, 2012 | Televison & Video
TV wont switch on
Check plug for power. Make sure that plug has adaquit power. These TV's take a lot of power make sure breaker pannel is OK. Check fuse in TV. Good luck.
Dec 11, 2011 | Televison & Video
POLAROID TLA 04641C AFTER VGA PLUG TV WON'T WORK
i am having the same problem.. did u ever got it fixed?
May 10, 2009 | Panasonic Televison & Video
Tv wont turn on
Had the same issue. The biggest task was figuring out how to take the TV apart. Two screws at the top, three each on the tires which I gently pried off with a flat screwdriver using the center of the wheel to pry from, two screws that were hidden under the tires and the two screws at the video plugs at the back. Next remove the circuit board by removing the 4 screws. BE EXTREMELY CAREFUL AS HIGH VOLTAGE IS STILL PRESENT WITHOUT BEING PLUGGED IN!. If you do this carefully you wont have to unplug all the plugs. If you do have to remove them mark each one with a colored marker marking the board and the plug. This helps when you have to plug everything back in. Now looking under the back of the board the tall black high Voltage transformer that has the red wire going to the TV tube has really poor solder connections. I found three cracked. I re-soldered all ten of the pins. Plugged everything back in and now it works.
Mar 13, 2009 | Disney DTD1363-CAR 13" TV/DVD
When i unplug my tv and plug it back it wont turn on, and after many tries of plugging and unplugging sometimes it turns on
Do you have a wall switch on that receptacle , maybe , just maybe, somebody is playing games with ya ...lol...
Oct 12, 2008 | Panasonic PT-53WX54 53" Rear Projection...
No power wont turn on
The Slight pop will be when the cors plug contacts the plug on the TV, and just a warning it is very dangerous to yourself and detrimental to any electrical appliance if you do this. when plugging in you should make sure everything is switched off before doing so and once all cords are connected you can then turn the power on. As to your problem I think you may have cooked your power supply inside your tv. You may need to have a technician look at it and diagnose for you. Hope this Helps.
Feb 13, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
