Question about Kitchen Ranges
Have a chef glendale stove with glass top,the large element has gone and i can not find a model number. only letters being EGUSFCW. SERIAL NO 2101013750. the stove is about 10 years old
4 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: How do I raise the stove top of a ceramic glass mo...
Open the oven door and look up across the front for 4 screws.
Eric
Posted on May 23, 2010
  • 274 Answers
SOURCE: I have kenmore electric stove. the two large element dosen't work
try the controlls or switching the elements with the other buners.
Posted on Jul 08, 2010
Replace fuse on ge glass stove top
Maybe the top you can open above switches.
Mar 17, 2013 | GE Kitchen Ranges
HOW DO I REMOVE THE LOWER ELEMENT OF A MAGIC CHEF STOVE OVEN
What is the complete model number of your unit? Look inside the door area.
Nov 28, 2012 | Magic Chef Kitchen Ranges
My magic chef stove model number CER3760AAW and Serial Number 14616100WF has a glass cooktop and it has been broken. Can the cooktop be replaced? If so where do I called to get it fixed?
The cooktop can be replaced and is available from Sears for $263.57
Part # 74003377
Substiture part# 12001393
Can be ordered online or by phone
Jan 04, 2011 | Magic Chef CEC1430 Electric Cooktop
I have a maytag performa ceramic top stove andwhen I turn on the oven it will only heat up to 230 degrees
I have a Maytag Performa Ceramic stove top which I have "washed" the serial number, I broke the glass top and need to replace it, but I don't have the model/serial number. If anyone has one please give me the numbers. Thank you
lilkadoc@hotmail.com
Apr 27, 2010 | Maytag Kitchen Ranges
Front right burner stopped working
Often, this will be due to the element. The easiest way to troubleshoot is take a matching element(if possible) from the other side of the stove top and see if that works in the receptacle.
There should be some letters after the model numbers you listed. The last three letters also lets me know what type of top you have on your stove to guide you through how to access the parts. Make sure you write the full number with all the letters before ordering parts.
If you have the glass top or ceramic model, the connections are different than other types. The manufacturer warns customers and nonservice personnel to never try to lift these cooktops. If you would like to pursue changing or testing this element despite that caution, there is a picture of an element and switch below.
On some flat top models, you need to open or take off the over door before you can lift the top. Most stove tops will then lift off, but you may need to take off a screw or two.
Also, on Canadian models, the front two burners will not operate during oven cleaning mode. If you are a Canadian user, try to reset your burner by turning on and off at the breaker. Canadian users should also make sure that the timer is not set and open the oven door fully to make sure toasting is not engaged.
Porcelain cooktops simply lift from the front and are held open with metal supports. Replacing coil type elements on models with drip bowls (not flat top) is very easy; you simply pull out the element and replace with a new one that can be purchased in large chains and appliance stores.
You should check the receptacle and wiring underneath the stove top for signs of visible dirt, grease or other abnormalities such as burns or frays. Turn off the power, and make sure the wiring plugs are tight.
Make sure the plug in end of the coil element is not burnt or damaged. Check the coil for rough or discolored spots. Follow the wires under the stove top that plug into the coil receptacle to make sure that there are not burnt, frayed or broken areas on the wire coatings.
Testing the element for continuity and possibilities like the receptacle and infinite switch requires special tools. Testing the infinite switch would be extremely dangerous as it is done live with 240 current (unless you live outside the US). If you have testers, you can check the integrity of all of the above.
Another less likely cause for elements not working is the knob that controls the burner being damaged on the inside. You can pull a different knob to see if that works, but this kind of issue is usually obvious because it does not fit snugly and has play when you turn it.
Finally, if you are going to replace the element, or replace the receptacle or switch, make sure that you take the old ones with you with the full model number. Before pulling wires, take a digital picture or mark wires with tape/paint so that you remember how to reconnect.
Check your parts before leaving the store, so that uninformed clerks do not steer you wrong. If you need further info on how to remove and replace the items shown, leave comments. But, take a look under the hood first, because you might be surprised at how simple it all is. I hope this helps
Dec 20, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Broken glass top for my gas stove
You can buy just the glass for your glasstop stove. I too need to replace my glass...I have a whilpool electric glasstop. Its not cheap...may just buy new stove. I priced just the glass for my whilpool at the cheapest I can find for $320.00. Thats a lot. Mind you its not the elements under the glass..its just the glass! So...idk bout you, but a whole new stove might be my best option. If you want to price the glass for your model just keyword search your number and brand of stove and type replacement glass. GOODLUCK! :)
Feb 16, 2009 | Frigidaire FES367 Electric Kitchen Range
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
My Magig Chef Glass Rangetop
This part can cost over $400. It is usually not worth fixing. NEVER operate the stove with a cracked top. This is tempered glass and it can just explode! It is also a dangerous electrical issue. Liquid can drip down through the crack and contact the live open element.
Jul 13, 2008 | Magic Chef 30 in. 8241RT Gas Cooktop
MAGIC CHEF TIME SAVOR GLASS TOP
Hi - Please post the model number of you appliance, it will look something like CEC1536.
Thanks.
Jul 02, 2008 | Magic Chef 9512 Electric Single Oven
Kitchen Ranges Logo
388 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
