Question about Schlage BE365-CAM BE365CAM619 Satin Nickel Electronic Security Camelot Elec
Keypad will not even light up - battery might be dead - have no key to get in - suggestions
  • 963 Answers
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt 365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 08, 2011
2009 holden cruze sometimes won't start engine cranks twice then goes dead immobilizer icon lights up on dash and hazard lights come on automatically. had scan that suggested key battery needs replacing...
Sounds more like the car battery than the key battery. Did you get the battery tested? you can do a cheap test with a multimeter if you have one. Your car battery should be no lower than 11.9 volts, with 12.5 being ideal. Even this isn't precise until it's load tested however.
Oct 22, 2014 | Cars & Trucks
Left turn light stays lit though battery is dead
have a load test done on the battery as there may be a dead cell Have an auto electrician check the reason for the indicator light staying on
Feb 27, 2014 | Mazda Cars & Trucks
2003 Aurora, left key on and battery went dead. Recharged battery. Won't start. Turn key to on, security light out and check engine light on. Move key to start and nothing, back to on, one minut
Very interesting site here.. regarding your problem. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Another thought.. even though you charged the battery, it's not at all uncommon for a car battery to be very damaged by fully discharging. Especially if not new-ish. One or more cells in it may be bad causing the overall voltage to be under normal. This alone can cause the problem you have. I would try jumping it with another car or test the battery to see if it's got at least 12.7 to 12.9 volts when sitting doing nothing. Good luck.
Nov 28, 2012 | Cars & Trucks
95 ford explorer battery went dead due to lights being left on, now keypad doesnt work
try closing and locking all the doors then unlock the drivers door with the key
Feb 26, 2012 | 1995 Ford Explorer
Hope you can suggest a solution to my problem with the 976LM Security Keypad. I did not work so assuming the battery needed to be replaced I inserted a new battery. But there is not life in the keypad....
It is never necessary to change the access code due to non use. It is the opener that remembers the code not the keypad. If the keypad doesn't even light up when you key in the code and press enter and you are certain the battery is good then the keypad has just failed and will need to be replaced.
Feb 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster key pad isn't working at all. I
There should be a small phillips head screw and then the cover slides down.
Jun 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
2007 Jaguar VDP
Hey John,
This is very common, because your battery is dead your remote isnt going to work. So what you have to do is look by the license plate light bulbs, their is a key hole wear you can insert you key and open the trunk to charge/ or jump start your battery
May 26, 2008 | 2007 Jaguar XJ Vanden Plas Sedan
Nokia N90 key pad not working on some numbers
go to nokia care centre for handset service...might b problem with keypad....and need to replace battery....
Oct 16, 2007 | Nokia N90 Cellular Phone
Schlage BE365-CAM  BE365CAM619 Satin Nickel Electronic Security Camelot Elec Logo
338 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
