Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
THE ANATANNA CONNECTION BROKE OFF, IS THERE ANY OTHER WAY TO HOOK UP THE CABLE TO THE CABLE BOX? THANKS
    Brigadier General:
  • 8,909 Answers
You need to repair or replace the socket. A person good with a soldering iron will be able to fix it I'm sure.
Hope that helps.
Posted on Jan 02, 2011
Cable broke on blade engagement, some one else took it off. I need to know how to get it back on, grass is getting high. can you send me a picture of where it hook under mower.. Thanks.
didnt specify unit --generic answer ---on most decks will see a pully with a spring or swivels look for a connection there
May 03, 2017 | Garden
Cable connection broke off bake of unit
if i was u id take to expert as i have had same problem once found cable was incased inside box very had to open so took to repair shop didnt cost alot
Nov 27, 2012 | Panasonic TH-42PX60U Television
Can' hook up the cable cause internal cable broke
If the coax fitting is damaged or broke off you can with a box connect via the rear jacks---most boxes have rear av or component outputs for this.
This bypasses the coax input---just hook up and in menu select that input (they are numbered and numbers on back indicate what number each is).
Let me know if you have questions or a comment.
Mar 19, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
How do I replace the cable connection?
You have two choices--either have the tuner removed and repaired--a new coax fitting installed OR:
If you have Cable, Direct TV, SAT, etc--you can route the signal into one of the audio and video inputs on the back of the set and bypass the tuner connection totally.
You can even use a old VCR---it does not have to be able to play tapes--just hook it to one of the Video and audio inputs and use it or a box to change channels
Repairing the tuner or replacing it may be very expensive--going into one of the inputs could only cost you the need to rent a box if you have cable etc.
If you have questions let me know--I am here to help people.
If this information helps you--rate this solution--I do this here for free.
SD TECH
Nov 02, 2009 | RCA D52W19 52" Rear Projection Television
Trying to connect cable box....
You should be able to pick any open audio device unless it says pre-amp only. If your manual shows a connection for a CD player or similar device it should support the cable box.
Good luck and thanks for using FixYa
Mar 17, 2009 | Onkyo TX-SR500 Receiver
Go video model dv-241 hook up to make vhs to work
There are a fews ways of accomplishing this.
It sounds like you may reversed your cable connections. Lets try these steps.
On the back of your cable box and your Go video VCR/DVD there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from Comcast to the (IN) connection on the back of the cable box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the cable box.
Step 3. Connect the other end to the (IN) connection on the back of your GO Video box..
Step 4. Connect one end of another spare coxial cable to the (OUT) connection on the back of your Go Video Box.
Step 5. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful.
Feb 10, 2009 | GoVideo Go Video DVD/VCR Combo
Set up
The specs I am reading online are saying that it has digital coax connection. If your hooking up hd cable or hd satellite box some of those have a digital coax output on them. If your hd cable/satellite box only has optical out the system you have says it comes with a optical to coax converter which is pretty cool. So you should definately be able to hook up that sound system to your cable/sat box digitally for best sound. The only other way would be to run stereo red,white cables from your cable/sat box to your stereo as a last resort.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 09, 2008 | Philips LX3950W System
The cable connector broke off the back of the tv
If you need to hook up to the barrel connector for cable or sat. you can use a converter box(Radio Shack) or VCR which both have a cable connection and then send it out component or Svideo.
Aug 18, 2008 | Televison & Video
it can be repaired.otherwise replace tuner
Nov 25, 2007 | Sanyo DS25390 TV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
