Question about Flotec FP0S2400A-03 1/3 HP 2,500 GPH Automatic Submersible Sump Pump
I Noticed that there was dirt in the sub pump system, I took it apart got it working, bit for some reason it wont **** up the water? I was wondering if you could tell me why? thanks
  • 658 Answers
Maybe you installed the check valve upside down and the water will not pass through a check valve that is facing down instead of up. If you took the bottom strainer plate off the pump and cleaned it out in there, the pump impeller may have stipped its splines and consequently only the shaft turns. Usually I find small stones, string wood chips etc. that stop the pump. The breaker should pop if it is the proper amperage, when stopprd up with debris. Good luck. Hope this helps you solve your problem. Please post to fixya.com if it does, so I get the credit for the solve. Let me know if you do need more advice. I will be happy to give you the whole lowdow on sumps if you wish.
Posted on Apr 08, 2014
My 2000 ktm 200 will not start
Hi, Aw98628 and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
200 EXC won start your thoughts
What to Do Check When Dirt Bike Won Start
1999 2006 KTM 125 200 Engine Workshop Repair Service Manual Download... $15 cheap
http://www.partsfish.com/page/oem-parts-for-ktm
KTM EXC 200 EXC Owner Manual
Mar 25, 2017 | 2005 KTM EXC 200 Usa
Fisher Paykel washer stuck on rinse cycle. Wont advance. Pump fine. Could it be the diverter valve. Took it apart and it was clean, no broken parts.
Check your belts, maybe belt slipping or pump jammed, if okay replace the electronics board. You can fry your electronics board if the water pump becomes jammed for any reason
Nov 08, 2011 | Fisher and Paykel GWL11 Top Load Washer
Lo longer steams
I just finished taking my wifes S3101 apart because of the same problem. I found the inlet and outlet hoses clear, so the problem had to be with the heater. I took the water side of the heater apart and found the outlet nipple clogged with dirt and sand. I live in VA Beach and my wife uses tap water. There was a lot of sand and dirt in the heater, so I cleaned all of that out, used a very small drill bit to clear the outlet nipple and then reassembled. It works fine now, and you will have to use distilled water if you want the unit to work for any period of time. The casing screws were a real pain to remove, so take your time.
Nov 30, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My sub pump is running every ten seconds. It
Yes, You have a bad check valve. Sometimes dirt gets stuck in the check valve and the dirt will not let it shut. If you can, take the piping apart near the check valve and verify that the valve is bad ans that it is not simply being held open by debris.
What happens when the valve does not shut is that the water in the piping will just run back into the pit and make the pump continuously cycle...That sounds like what is happening to you.
Heatman101
Mar 16, 2010 | Plumbing
Does this model fully drain?
Switch immediately to a Brand Name Dishwasher powder (like Electrosol or Cascade.)  Avoid gels, tablets and never use a dish soap that is meant for washing dishes in a sink.  This will solve the "bubbles" problem.
Yes, dishwashers do maintain some level of water inside to keep the pump seals/gaskets from drying out or seizing. As long as the water down there is clear and has no odor, you and your apartment's dishwasher is fine.
OK?  Post back with any more questions.
Apr 14, 2009 | Dishwashers
Washer is Leaking Water
Replace pump. The newer ones are a little thicker. Hair and sand will cause them to fail, like bath mats and door mats.
Apr 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My xbox wont read my game disc
if you can't send the xbox back to Microsoft this worked for me.
The 360 would spin the game up and say reading but than stop and do nothing.
I took the case apart, took out the cd drive, took that apart so i could get to the laser.
put a little big of very clean water on a q-tip, wipe the laser lens down and use the dry side to dry it off.  put it somewhat back together and test, this worked fine for me, it read a disk no problem.
Feb 21, 2009 | Microsoft Xbox 360 Console
WASHING MACHINE WONT SPIN
How much you loading in the machine?
Since when this problem arised. How much old it is?
Is tt spins, but doesn't pump.
If your washer spins but doesn't pump the water out, the drain line is probably clogged.
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
Let me know in bit more detail so I can investigate further.
Oct 06, 2008 | Crosley Washing Machines
Dirt/Collection Tank Bissell Little Green
I had the same problem, so I took out the black stopper, and soaked the whole thing in bleach water for about an hour, then I took a hand full of " aquarium " rocks and put them inside the tank, and shook them inside using a bit of the same water and then got rid of the rocks,( the rocks worked as an scrubber ) .... it worked pretty good
Sep 22, 2008 | Bissell 1400 Little Green Pro Canister...
Flotec FP0S2400A-03 1/3 HP 2,500 GPH Automatic Submersible Sump Pump Logo
65 people viewed this question
Top Flotec Electrical Supplies Experts
 Kenneth
Kenneth
Paul Nielson
Paul Nielson
Are you a Flotec Electrical Supply Expert? Answer questions, earn points and help others
