Question about Intel D865PERL Motherboard
Intel D865PERL Mother board with 4 DIMM's (identical 512 MB 400 MHZ) installed will not post and shows no video. Removed DIMM's and installed them one at a time in slot 0. Machine boots normally. Installed one DIMM in slot 0 and one in Slot 2 (Dual channel mode). Machine boots normally. Installed 1GB DIMM in slot 1 with 512MB DIMM in slots 0 and 2. Machine boots and recognizes 2 GB of memory but is in single channel mode. Problem appears to be caused by adding 4th DIMM in slot 3. Any idea why machine will not boot in dual channel mode with 4 identical DIMM's installed?
The-Only-Sol
  • 144 Answers
SOURCE: DG965RY board can not reboot with 'restart' button on windows Xp
Run with only two RAMS each in one of the DIMM slots. Three RAMS may not work unless supported by mobo or being exactly identical in their specs..
Posted on Dec 04, 2008
go-tech
  • 41 Answers
SOURCE: DG965RY boot problem
Hi niraj73
1. Remove the 1 Ram module from Slot B Channel 0.
2. See if problem is still there.
3. If not get another Ram module of same spec to fill up all 4 channels.
4 If error still there swap the removed Ram module with one of the Ram modules still installed. One of them might be faulty.
Regards
Go-Tech
Posted on Dec 14, 2008
  • 85 Answers
SOURCE: Memory synchronization Problem
Did you reset the cmos on board first?
Posted on Jan 18, 2009
  • 272 Answers
SOURCE: Intel D915GUX Memory Upgrade Problem
You should Know that, none of the 32 bits Windows can detect more than 3 GB of ram. I think, compatibility cam be a fact but dont forget this one.
Posted on Apr 04, 2009
SOURCE: RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Posted on Jan 16, 2010
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
What is the max memory that i can install on an intel motherboard e210882
The Dell E210882 system board is compatible with PC2-3200 (400 MHz) or PC2-4300 (533 MHz) DDR2 non-ECC and unbuffered SDRAM. The motherboard has four slots for memory. Capacities compatible include: 128 MB, 256 MB, 512 MB or 1GB. The maximum installable RAM is 4 GB.
let me know if it helps you : ) replay to me as soon as you solve your problem : )
Sep 15, 2011 | Intel Motherboard
I have a dc7600 and im trying to find out how to identify the what type of mother board it has so I know what to do next, so my question is how do you identify what motherboards in it without downloading...
The specs for your computer are as follows:
Processor
Intel® Pentium® D Dual Core Processor 820
• 2.80 GHz, 2 x 1 MB L2 cache, 800 MHz front side bus
Operating system installed
Genuine Windows XP Professional SP2
Compatible Operating Systems
Genuine Windows 2000 (Web Support), Genuine Windows XP Professional SP2, Genuine Windows XP Home SP2, FreeDOS, SuSE Linux 9.3
Chipset
Intel® 945G chipset
Standard memory
1 GB (512 MB x 2)
Maximum memory
4 GB DDR2-Synch DRAM
Memory type
DDR2 PC2-4200
Memory slots
4 DIMM
Memory Upgrade
Expandable to 4 GB through three industry-standard DIMM slots
Chipset
Intel® 945G chipset This is *********** board the below link lead to the specs for your motherboard.
http://ark.intel.com/chipset.aspx?familyID=8765
May 18, 2011 | HP Compaq dc7600 Small Form Factor PC...
I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
Third party memory vendors may use the same module part number with different
DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
Apr 10, 2011 | Intel Server Board S875WP1-E (S875WP1LX)...
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
I have a mainboard of model D845GVAD2------------------------AAC18931-104. It has already intall the Intel celeron processor of 1.8GHz. Now I want to upgrade my processor. So what high frequency processor...
The Intel® Desktop Board D845GVAD2 supports a single Pentium® 4 processor with a system bus frequency of 400 MHz or 533 MHz, or a single Celeron® processor with a system bus frequency of 400 MHz.
So you can install upto 3.06 GHz 533 MHz(cache memory) processor and also update the ram 2 GB 400 mhz.
Dont install Prescott processor.
Hope it will help you.
Dec 31, 2010 | Intel Desktop Board D845GVAD2 Motherboard
S-ATA Hard Disk not detect
hi Dear,
You have to update your BIOS. If you have intel mother board just go thought their website and download BIOS Flash utility of your particular Board and Update BIOS.
The above fix will surely solved your problem.I had same problem as you and it's now fixed.
May 10, 2009 | Computers & Internet
Jan 18, 2009 | MSI K8N Neo3-F Motherboard
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Intel D865PERL Motherboard Logo
118 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
