Question about Minolta EP1083 CS/PRO Copier
When you run the code appears CO5, and then after 3 seconds does not operate copy machine
    President:
  • 1,138 Answers
Check and replace the thermal fuse, located within the fusing unit, under the top cover and where the paper exits the machine.
Posted on Jan 02, 2011
How do i reset this error code E000002
Hi. press aditional function
press 2
press 8
when #sssw appear on the screen search with arrows in the touch panel until CLEAR appear on the screen
press ok once
and search with arrows until ENGINE appear on the screen
press ok once
ERRCLR appears on screen . press ok one more time
turn off the machine from main switch for a few seconds
turn on again and make copy test .
if problem persist replace the fixing heater.
May 03, 2015 | Canon ImageRunner 2525 Copier Canon
Error C3102
The Fuser is not turning... follow these steps
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the T reset appears
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, wait 10 seconds and turn the machine back on, this should reset the service code and with any luck the machine will run!
May 03, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Cannon image runner 2525 error code E0000002
on the control panel press:
aditional function
aditional function
should appear ins screen "#sssw"
search with the left arrow until "CLEAR" appear on screen
press ok
search with the left arrow until "ENGINE" appear on screen
press ok
the screen displays: ERRCLR press ok again
turn off the machine from the main switch (located on the left side of the machine) for 5 seconds
turn back on the machine and try to make some copies
if problem persist replace fixing film assembly
Apr 28, 2014 | Canon imageRUNNER 2200
Change my aficioDSM635 language
A. Press the {User Tools/Counter} key.
The User Tools main menu appears.
Note
? When the key operator code is set, the key operator code input
display appears when changing the default settings. Enter the
registered key operator code beforehand.
For key operator codes , see "Key Operator Tools", General Settings Guide.
B. Press [Copier/Document Server Features].
The Copier/Document Server Features menu appears.
C. Select the menu you want to set.
The setting display for each menu appears.
Reference p.83 "User Tools Menu (Copier/Document Server Features)"
D. Change settings by following the instructions on the display panel,
and then press [OK].
Exiting User Tools
A. After changing default settings, press [Exit] on the User Tools main menu.
Changes to User Tools are complete, and the machine is ready to copy.
Note
? You can also exit User Tools by
pressing the {User Tools/Counter}
key
Dec 17, 2010 | Office Equipment & Supplies
Lanier ld 435 color print code sc548
re install fixing unit and do the sc reset. press clear mode 2x 107 press clear/stop until COPY SP appears press Copy Sp then exit, turn off machine then on after 5 to 10 seconds
Aug 23, 2010 | Lanier Office Equipment & Supplies
Ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Dec 28, 2009 | Ricoh Aficio 1035 Copier
One number of photo copy machine drum cartridge wasinstalled. It worked once. Now machine is showing letter H and 4 flickering alternatively on the screen. Because of this none of the function of machine...
This code is almost always a false code. I would try clearing it by entering the following key sequence:
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" (Note that the exposure mode key is the far left key and that these 4 keys must be pressed within 4 seconds)
The display should have gone blank if these 4 keys were pressed properly.
Now enter 14 as if you were making 14 copies then press the Print Button.
This should clear the H4 code and the machine should operate normally.
If not and the H4 comes back then you have either a thermal fuse or heater lamp failure.
Good Luck
Nov 10, 2009 | Sharp AL 1631 Copier
Error code C400
that code points to your laser unit. you will have to have a tech install a new or refurbished one. then code will clear.
hth,
razoras
May 28, 2009 | Copystar CS-2030 Copier
29 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
