Question about Mitsubishi WD-65732 65" Projection HDTV
Yellow status light is on, ck air flow message comes on and says tv will power off in three seconds. tv is clean inside and out????
    Brigadier General:
  • 8,909 Answers
Check the fans are free and running. If a fan has stopped that message will be produced.
Hope that helps.
Posted on Jan 02, 2011
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
A message flashes at the bottom of the screen
tv is overheating.  possible that fan not working or temperature protection circuit faulty.  check fan for excessive dirt first.  could be as simple as cleaning the fan
Jul 29, 2010 | Mitsubishi WD-57731 57" Projection HDTV
On-going problem where tv is turned on and almost immediatley says it will shut down because of an air-flow problem. After turning on several times it used to then work but lately it just repeats the same...
The fan is shorted and might be dead.The projection bulb been in the tv and used for the last 3 years?The projection bulb,life span are over.Require a new projection bulb.
Jul 04, 2010 | Mitsubishi WD-57732 Projection Television
Air flow is blocked
In the 65" TVS there are 4 or more fans One of these is not functioning Probably the one over the power supply itself This will cause it to heat very quickly and shut down in a matter of about 20 seconds.
only way to find out which fan is not working isw to remove the back.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Mitsubishi WD-65731 65" HDTV
04road king ck engine light comes on like normal
if it's yellow you have a fuel problem, dirty air cleaner or something blocking air flow air flow meter giving you some problesms, best to get it to a shop and hooked up to a diagnostic system. If it's red quit running it and take it in for repairs.
Jul 25, 2009 | 2003 Harley Davidson FLHR Road king
STATUS LIGHT YELLOW, LAMP LIGHT GREEN: TV TURNS OFF.
have you checked the air filter located on the side of the unit? Also can you hear the fan start as soon as you plug the set in?
Apr 09, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Auto power down
have you tried cleaning the air filter?
Mar 26, 2008 | Mitsubishi WD-65731 65" HDTV
Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Aug 22, 2007 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-65732 65" Projection HDTV Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
