Question about Jenn-Air JED8130 Electric Cooktop
MY wife boiled over her tea pot of water and now the pilots on all four burners continue to click as if you turn on the gas to light the stove.
  • 1,543 Answers
The water has shorted out at least one of the igniter switches. Disconnect power to the unit and let it dry out for several hours and it should be just fine.
Posted on Jan 02, 2011
Testimonial: "Thanks for the help. you were right it is working fine thanks again"
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
One plate in Bellini induction cooktop continues to flash with a pot on it, yet the pot works on the other 3 plates. How do I fix?
Had the same problem after overusing one of the bigger elements on my bellini induction stove / cooktop to boil copious amounts water. Element eventually stopped working and would just flash power level similar to when it cant recognise an induction pot, but also made a clicking noise over and over. My solution was to turn mains power off at meter box, and back on to reset the stove. When power came back on stove was working again! might have reset some sort of cutout sensor inside stove but cant be certain. Anyway, worked for me so give it a go and see if it helps. good luck.
Feb 13, 2012 | General Cooktops
Gas was turned off and igniters keep clicking?
As I did not see what occurred, I suspect that the tea kettle boiled over and sent water into the burners. The igniters kept clicking and I eventually turned the gas back on. Will have to replace one igniter which apparently went out and have to light it manually at this point.
Dec 11, 2009 | KitchenAid Cooktops
Whrlpool Electric Stove Top Burners
this is a ceramic top i am guessing.
this is normal, it isthe way it is designed.
it does this so that it does not cause a heat fracture to the glass.. it will continue to turn on and off.. but if you put a pot of cold water on it you will find that this will happen alot less frequently.
Oct 09, 2009 | Cooktops
Short in knob
Replace the spark switch module on the bad burner.
Sep 29, 2009 | Amana AKS3040 Gas Cooktop
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Mar 04, 2009 | Thermador PC36 36 in. Gas Cooktop
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Flame on gas hob not correct.
I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
Apr 29, 2008 | Cooktops
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Jenn-Air JED8130 Electric Cooktop Logo
182 people viewed this question
Top Jenn-Air Cooktops Experts
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
