Question about Amana Refrigerators
Came home and all food was spoiled. Refrigerator was not blowing any cool air. I hear the motor but no air. Both freezer and refrigerator were not working. Refrigerator is about 14 years old. Does the refrigerator use freon?
  • brett_perez Jan 02, 2011
    where abouts is the freon nozzle located?
  • 2,382 Answers
Hi, this whole idea is something you should have a qualified refrigeration technician doing. There's a point in the piping from the compressor to the radiator fins, which can be located behind, underneath or inside behind a plastic panel, where the freon is both installed and removed. It requires special equipment to do both and if you get moisture in the system you can pretty much kiss it good bye. Let a professional tech do this.
You probably don't need to add freon to your refrigerator. People usually ask this question when their refrigerator doesn't seem to be able to keep up with the stuff you put in it.
1. check the bottom of your fridge, there is an air intake grill at the bottom, make sure this is clean and free of lint/ dust
2. make sure the thermostat inside is set properly
3. don't overload the freezer section. the cold air for the fridge comes from the freezer, and if you have too much stuff in the freezer, it will stop the air from being able to flow to the refrigerator section
4. Finally, if you're a little bit technically capable, check the back of the refrigerator, for a small 1/8" hose going down the back of it- make sure this line is clear and free of gunk
If your refrigerator needs freon, there would have been a clear moment when the freon was let out- puncture, break, crack, etc. If this happened there would be oil all over the bottm compartment of the fridge, and probalby the wall behind it- and the compressor would not run at all.
Posted on Jan 02, 2011
  • 2,973 Answers
Brett,
Yes you are right. It does use the feron gas to cool the innards of the fridge. The gas may have leaked out (14 years service is a long one). It should be refilled to make it work again. Please call a professional for the purpose.
Why my refrigerator stop cooling the fridge side? The freezer still freezing but my food is spoiling
there is an air damper that controls the temperature in the refrigerator . if set too low food will not be cold , however they do fail
May 04, 2016 | Refrigerators
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
Hi my side by side wards refrigerator and freezer doesnt always get cold enough some times it will make ice and keep milk cold and other times wont make anything cold. it spoils milk one day and next day...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Refrigerators
My freezer is working fine, but my refrigerator is barely cool and both units are controlled by the same setting knob. This just happened all of a sudden. Everything in the refrig is spoiling.
It the fan blowing up in the freezer and no cool air is coming down to the fresh food section then I have seen this before. The drain for defrost is clogged. Instead of draining out it is pooling up between the freezer and fresh food side. You gotta thaw out the ice box and open the drain. Nothing to buy. Oil the fan motor with zoomspout oiler.
Jun 29, 2011 | Whirlpool ET1MHKXM Top Freezer...
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
It is not cold enough food is starting to spoil
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 03, 2010 | Amana ABB1927DE Bottom Freezer...
The refrigerator is not cooling enough.
You will need remove the screws in the back of the freezer section, check to see if the little fan is turning, if not you will have to replace the fan motor, this is what circulates the air and keep the fresh food side cool.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Nov 24, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
48 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
