Question about Canon PowerShot A95 Digital Camera
When I turn the camera on, a clicking/whirring sound starts. The screen is black and E18 appears on the bottom left.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 10, 2011
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
May 21, 2009 | Canon Cameras
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
E 18 message
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 04, 2009 | Canon PowerShot A75 Digital Camera
When I try to zoom, screen goes black and "E18" appears in bottom corner
I won't say this is a solution but to prevent the lens retraction E18 message which seems to be common with Canon zoom lenses, I put the extension tube on mine. Sometimes I put a polarizer lens on it but usually I just leave it on to protect the lens when it is on. I have dropped it (on the carpeting at home) and never had a problem. If you have a Canon with a zoom lens, get a lens hood for it ASAP!! My wife's A520 has one on hers too. No problems.
There are lots of other places on the web with suggested fixes. Keep looking and keep enjoying this camera. Merry Christmas all.
Oct 31, 2008 | Canon PowerShot S2 IS Digital Camera
E18
E18 is the canon fault number for lens error. Is the lens stuck out? does it click when the camera is switched on? Try lightly tapping the lens on a hard surface. This sometimes resets the lens. If all this fails take it to bits! (but watch the flash module as this can give a nasty shock.Big black capacitor) You will see the lens module take the it to bits carefully and re seat the components. I have done a few over the years. It takes about an hour. If you have any more issues contact me.
Sep 04, 2008 | Canon PowerShot A400 Digital Camera
Whirring sound after start then black screen with E18 in bottom corner
this is very easy to fix- switch your camera on, grab then lens around the edges, and carefully give it a firm twist. It should click and turn on.
Dec 18, 2007 | Canon PowerShot A400 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
E18
The E18 error is fairly common. Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Nov 04, 2007 | Canon PowerShot A75 Digital Camera
Screen is showing E18
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon PowerShot A520 Digital Camera
Camera was dropped, lens will not retract, when on/off button is pressed the initial screen and sound appear but then the camera makes a kind of warning sound and E18 appears in the lower left hand co
Perhaps the lens got bumped (if the camera was one when it was dropped) and is out of place. Mine did the same and I sent it in (it was within warranty) and Canon fixed it.
Mar 18, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot A95 Digital Camera Logo
18 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
