How to disconnect WD440 Hotpoint Aquarius washing machine?
  • 876 Answers
If you want to completely disconnect it, please do it in this order::
>Make sure that there is no laundry in the machine
>Turn the machine off
>Unplug it from the wall socket and secure the cord to the top of the washer with a piece of duct tape.
> Turn the water off at the faucets that supply the washing machine.
> Loosen each hose and turn it into a bucket or sink to drain it as much as possible.
>Secure it with th4e opening up with duct tape to the side or back of the washer so that you do not drain leftover water all over the floor.
>Finally do the same with your drain hose. You may have to pull the washer out from the wall to do this, but you need to pull the drain hose out of the drain, and bend it to drain to a bucket or sink.
And then secure it to the washer as above with the opening higher than the tub.
> At this point you can move the washer to an area outside or wherever you want to take it. If you are moving it outside, you can disconnect the water hoses and drain them completely and even keep them if they are still good, and you are replacing the washer. You can also remove the drain hose completely if desired.
>Good luck to you. Thank yo for using FixYa. Please rate this solution.
Posted on Jan 02, 2011
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wd440 drum sticking when rotate by hand
The drum on my hoover washing machine is sticking / grinding, can anyone advise what it may be? Thanks
Oct 14, 2009 | Washing Machines
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Sep 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wd440 confusion over washing machine pipes
Hi is there another valve? If so then you can connect them by a Y piece. Problem solved.....
Feb 26, 2009 | Washing Machines
u might have a blockage in the drainpipe. hope it helps. good luck!
Jun 16, 2008 | Hotpoint Aquarius WD640 Front Load...
AQUARIUS HOTPOINT WD440
How many times does it flash.
it still sounds like you have an obstruction in something.
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
