Question about Toys
Should the tail blade spin? That on my Syma S107 Does'nt! the blade is loose and spins when you blow it but does not when powered.
  • susanlee2 Jan 04, 2011
    Thank you Jyackle5.
    You have confirmed my fears!
    Happy new Year!
    Jeff
    Many thanks Jyackie5-You have confirmed my thoughts.I will proceed as you suggest.
    Happy New Year to you!
  • 8,197 Answers
Yes the tail blade need to spin when powered. If it is not spining then you need to replace the blade and motor. I do not know where you can get parts for it though
Posted on Jan 04, 2011
S107G upper blade doesnt rotate,and leans to the side. lower blade spins...but no take off. brand new out the box......sup?
Check that the bottom gear/cog is engaging with the motor drive gear. This is a common fault and usually just need to move the cog on the motor.
Kind regards, Julian
rccontrolfreak.co.uk
Oct 25, 2013 | SYMA Toys industrial New Syma S107 Mini...
My S107g worked great for a week but then the top blade just stopped moving. The lower blade is spinning away and the top one sits there limp. What's going on?
well firstly you still have warranty on it, get them to replace it..
the blades are controlled by a motor and a gear system in the helicopter itself. The gear is broken or the motor is wedged in by the gear. or simply burnt out, You will need to open it to unwedge the gear and if it spins when you turn the gear, you need to replace the motor. Both blades use separate motors that's what allows it to trim (turn) when one set spins faster than the other, It goes straight when both blades spin at the same speed.
Dec 29, 2012 | SYMA Toys industrial New Syma S107 Radio...
My S107G Metal Series will not take off just sits and spins how can i fix
If there are two blades that turn in opposite directions, perhaps the blades are reversed. If that is the case then they are pushing the helicopter down instead of up.
Sep 09, 2012 | SYMA Toys industrial New Syma S107 Mini...
Syma s107 hit a dangling string that got tied up instantly and seized the rotors. now lights up but blades don't spin when throttled. What can I do besides replace the helicopter?
I was flying my syma s800g and hit the ceiling fan chain. When I attempted to fly it would spin and fall over. The problem was I broke the two small plastic pins on the top rotor holder. Ordered a new top rotor and flies fine. Then on my s107 I flew into a door and the top rotor had zero spin although the motors worked. In that case the screw that sets the top rotor onto the middle shaft loosened resulting in no lift and also tilted and fell over. This was fixed by securing the set screw properly. So in both instances it was similar effects due to the top rotors not spinning in sync with lower blades.
Jun 03, 2012 | SYMA Toys industrial Syma S032 Ready to...
My heli takes off and will slowly begin to make large circles spinning out of control.
TRY ADJUSTING THE TRIM ON THE TAIL ROTOR AS THIS IS WHAT KEEPS IT FROM SPINNING
HOPE THIS HELPS
Aug 21, 2011 | SYMA Toys industrial New Syma S107 Radio...
The tail rotor on my Syma s107 metal series helicopter won't spin. the battery is fully charged. the top rotor still spins. i don't know what to do
It seems tail motor is not working.
S107 knows to come with faulty tail motor.
If you open pilot cabin, you should see blue and red (or green and red) wire. See if they are welded on the motherboard.
If they are, then tail rotor is not working properly.
Mar 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
My sons S107 lower rotors would not turn. I disassembled and solved a gearing problem. At this time a wire came loose that supplies power to the tiny little prop at the tail. I fixed this problem too. ...
Check if s107 is fully charged.
Both rotors (lower and upper blade) should be working at full capacity. If either one of them is going slower, S107 won't lift up from the ground.
Check that gears are not too tight on each other. They should be able to rotate (leave cca 1mm space up/down between them)
Mar 23, 2011 | SYMA Toys industrial New Syma S107 Radio...
S107 wont fly forwards any more
Check the tail rotor blade for proper rotation. A lil wd40 could resolve this problem if it is not spinning.
Dec 26, 2010 | SYMA Toys industrial New Syma S107 Radio...
My syma s 107 copter transmitter dont connect5 to helis.controller light blinks
Try setting the heli down on a table and with the transmitter behind the heli, turn the throttle up until the blades start spinning. If that doesn't work, then I don't know how to help you.
Oct 03, 2010 | SYMA Toys industrial New Syma S107 Radio...
Syma s107 take off problem
The blades could be on up-side-down or The battery may not be holding enough of a charge anymore. If it's the battery, check out these Syma S107 Battery replacement instructions.
Jul 30, 2010 | SYMA Toys industrial New Syma S107 Mini...
Toys Logo
163 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
