Question about Rohl R3830-APC de Lux Pull Out Kitchen Faucet with Vacuum Breaker, Solid Le...
How do I get to the cartridge in a leaky R3830 (Rohl) pull out faucet?
5 Suggested Answers
  • 171 Answers
SOURCE: rohl 3810 faucet nut not engaging threads
Hi murphygm,
I'm Harvey the Master Plumber.
Your problem is: You have replaced a leaking Rohl cartridge in your kitchen faucet, but when you
replace the nut holding down the cartridge, the threads of the nut do not
engage. You have tried to push hard down on the cartridge while you turn the nut,
but to no avail.
Assuming you have the correct cartridge, I find it helpfull to take pictures with my cell (easily deleted later) as I disassemble to make sure I'm getting the new one in exactly right because there are only two reasons why the new cartridge won't go all the way in. 1 It's the wrong cartridge or
2 something's not right. Take the new one out and check that everything is correct, it's easy to make a small mistake. That's it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
  • 152 Answers
SOURCE: Leaky faucet
Finding brand specific replacement parts in stock for a 20+ yo faucet without a Mod.# is quite the task, implying that you would have to do a side by side compareson/inspection. If in fact that part is not obsolete.
Maybe you should consider replacing the entire faucet.
Good luck
Posted on Feb 23, 2009
  • 126 Answers
SOURCE: Rohl R3830 pull out faucet: loss of water pressure
try where the hose connects to the pull out spray,s/b a screen there
Posted on Jan 08, 2011
packrat1948
  • 528 Answers
SOURCE: how do you remove the
It just unscrews counter clockwise.
Posted on Feb 07, 2011
I have a leak coming out of the hole in the base of a Rohl pull-out faucet.
sounds like there's a kink in the line leading in,find the kink & unkink it,should help
Dec 08, 2013 | Rohl R3830-APC de Lux Pull Out Kitchen...
I have a R 3830 faucet and it does not change from spray to stream, it does both as the same time. Is there a rebuild kit for this problem, or what should I do to fix.
This function relies on water pressure. Remove the sprayer from the hose and check pressure. If good flow, replace the hand sprayer. If low flow from end of hose, remove hose from underside and check pressure going into hose. You may have blockage in the hose. Hose can be replaced by calling ROHL customer service at 800.777.9762
Mar 11, 2013 | Rohl R3830-APC de Lux Pull Out Kitchen...
Guide to Replacing Cartridge on Rohl R77V3
Look carefully at all the prongs and receiving slots in the body of the faucet into which the cartridge goes to insure proper match.
Mar 03, 2012 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
How do you remove everything to clean it, the faucet wont swivel left to right anymore
Remove the handle and the retaining ring (nut) and pull the spout up and off you may need to replace the o-rings found there and lube the area with a good plumbers lube, reassemble and you will be good to go.
Mar 03, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
How do you take the cap off of a Rohl R3810STN Single handle faucet??
Under the handle is a small cap/cover remove it and the handle set screw in right there.
Feb 13, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
The fucet will no longer move from side to side
Take the handle off and remove the retainer cup remove the the spout clean and lube. If the faucet is very old I would go ahead and get a rebuild kit and do it all at one time.
Feb 06, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
Rohl R3830-APC de Lux Pull Out Kitchen Faucet with Vacuum Breaker, Solid Le... Logo
171 people viewed this question
Top Rohl Plumbing Experts
Donni Steen
obsteiner
john h
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
