My remote control for my Zenith Television Model Z27X229 will adjust the volume, but it will not change the channel. I have changed batteries, but that didn't help. Do I need a new remote control? If so, which ones will work with this model? Thanks for any help you can offer.
    Scholar:
  • 133 Answers
The simplest solution would be to buy a new remote for testing purposes. I own a One-for-All universal remote (model URC-4220), which I bought at Walmart, for less than 10 dollars. It is compatible with Zenith TVs. (You can return it later, if necessary).
If the channel-changing problem is not resolved with your new remote, then you will know for sure there is a defect in your TV, which requires the expertise of a repairman.
Posted on Jul 09, 2008
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
My remote stopped working can it be reset
Hello;
I found the following reference to resetting anything related to the ZN110 remote:
"This remote control works well for all the basic functions on the television: changing channels, adjusting volume, and turning the set on and off. There is not a way to program the TV with the remote control, so if you need to reset the channels after a power outage, for example, you have to do it manually on the TV set itself."
Or it could just be batteries?
Feb 26, 2011 | Zenith ZN110 Remote Control
Sony trinitron kv32-s15 remote willnot change channels, but, will change on/off and volume.Also, manula channel up/down willnot work
Try to change channels by manually entering the numbers on your remote. If this works then you need to reprogram your channels.
Aug 21, 2010 | Zenith ZN110 Remote Control
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
Problem with remotes for our zenith e44w46lcd tv
It could be that the main board or the remote reciever is bad on the TV. The best thing to do at this point is to have a technician verify which one is causing the issue. Otheriwise it would be an expensive gamble to replace both boards. Please take a moment to rate my answer. Thanks..
Nov 25, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
Press the "TV" button on the remote to program the Philips remote to your television set
Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
Remote will not communicate with television
What kind of television are you trying to program the Zenith Remote to? If it is a Zenith TV, it should work after replacing the batteries. If not, the remote returns to the factory default to the Zenith Code. If you changed the batteries cuz the unit would not function, the remote itself may be defective. Replacements are still available at a ZENITH dealer at a nominal cost.
Apr 02, 2009 | Televison & Video
TV won't change channels or adjust volume
Do you have a universal remote? If the batteries are taken out for a little period of time, the remote will loose the codes and they will have to be reset. You can find the codes by google universal remote codes.
If you have a factory remote that came with the television, than it may be faulty or the sensor on remote or tv may need to be cleaned.
Mar 11, 2009 | Televison & Video
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
RCA tv and a zenith remote cl015
take a poop ans sculpt it into a new remote.
Oh, i would let it dry out in the sun for a couple days before attempting to sculpt, up to you.
Dec 01, 2007 | Radio Shack 3-in-1 Easy-to-Use Universal...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
