Question about Baxter OV300E Stainless Steel Electric Oven
Water coming out oven no steam and it will not get to tempeture
  • 43 Answers
If your oven isn't reaching temperature you will not get steam. Turn the oven on and verify that the oven is calling for heat by looking in the temperature window next to the arrow that says "heat" or "on," if the set temperature is 5 degrees higher than the actual temperature there should be a small red dot next to the arrow. Then observe the burner, does the exhaust fan come on, can you see the ignitor glowing, does the burner light, does it stay lit or go out after 4 seconds? You could have a dirty flame sensor, the small rod with a wire attached to it at the top of the burner, remove the flame sensor and clean it with a cloth, wire brush, or emory cloth.
Posted on Dec 30, 2011
Is it normal or safe for steam to come out of the air vents on my zanussi oven. Model ZCV66030BA? Doesn't seem very safe to me even though repair man says so
Our SamSung oven has steam coming out the vents when we cook certain things.
I think the repair guy is correct.
Jan 05, 2018 | Zanussi Ovens
Oven doesn't give steam but it does reach the temp.how can i fix that?
First locate the water solenoid valve. Disconnect the water line to the inlet side of the valve to make sure water is getting to the valve. Once that's verified, disconnect the outlet side of the valve. Activate the steam and verify that the valve opens and there's a good amount of water coming out of the valve. If no water comes out. Verify that the coil is getting energized with the correct voltage. If the correct voltage is present and you have no water coming out. Replace the solenoid. If everything is working then remove the left panel inside the oven to check for blockage in the steam manifold. The manifold consists of a pipe with several spray nozzles that spray water on rebar. Remove all the nozzles and activate the steam. Do this several times to purge any rust or debri. Clean the nozzles and replace them. You should be good to go.
Aug 25, 2015 | Baxter OV310G Mini Rotating Rack Gas Oven
My oven fills with steam and I can't bake cakes etc as they retain too much moisture
Your vents are blocked unless this is a steam clean oven. Check for continuos water drainage. Water valve could be bad. I need a model number.
Oct 26, 2013 | Ovens
Not steaming
check the holes have not gummed up from residue in the steam. It builds up over time.
Oct 23, 2010 | Combi Steamer electric built in steam...
I have a baxter mini rack electric oven and water started leaking out of the right side of the oven while cooking bagels. any ideas on what is causing this
Sounds like you have a water leak! The right side panel needs to come off. Here you will see your copper water lines. Try steaming while watching to see where the water is coming from, most likely its coming from the two spray nozzles that enter the oven near the top in the front and rear. If the leak isn't obvious have an authorized technician service the oven. A leak in this part of the oven left unattended could cause more damage and potentially a fire.
Feb 03, 2009 | Baxter OV300E Stainless Steel Electric...
How do I descale a Miele steam oven?
Put the tablet into the steam generator with about 1ltr of cold water, select the cleaning cycle on your oven. let it go through the cycle.
Hope this helps
Jan 31, 2009 | Miele DG155-1 Steam Oven Single
Can i steam clean my electric oven ?
It is NOT safe to do this due to the water content of the steam when it condenses.
Better to use an aerosol type oven cleaner.
Nov 30, 2008 | Whirlpool RBD305PD Electric Double Oven
Baxter OV300E Stainless Steel Electric Oven Logo
222 people viewed this question
Top Baxter Ovens Experts
Lawrence Oravetz
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
