Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Water won't spray from my bissell powersteamer pro - what could be causing it?
SOURCE: Bissell 1698 Powersteamer no spray
If it seems like the tank does not fit in securely, the round gasket that goes around the valve at the bottom of the tank may have come off and actually be in the hole in the bottom of the vacuum base. It looks like it belongs there but you can pull it out with some needle nosed pliers. After you remove it, put it around the valve on the bottom of the tank, then it will fit into the hole again and everything should seal correctly. Mine was not spraying and would not suction well. figured this out and now it works great again.
Posted on Sep 05, 2007
Agent Don
  • 310 Answers
SOURCE: Bissell Pro Heat Powersteamer- Filed it
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=606751
Bissell Pro Heat PowerSteamer- Filed it
Posted by wbdd on May 18, 2008
Filed it up, turned it on, as usual, but no water flowing from machine at any setting. Vacuum part works.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. It sounds to me that you may have a broken trigger release rod / valve or the bottom of the holding tank has a release valve that might not be working and would need replacement buy a new or a good used one, generally the valve underneath is part of the holding tank assm. So check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 30, 2008
SOURCE: Bissel 1698 PowerSteamer Pro Heat Plus - Manual
This is the link for an Adobe file for the manual.
http://www.bissell.com/images/UserGuides/1698.pdf
Posted on Jul 21, 2008
reddevil6
  • 1673 Answers
SOURCE: bissel powersteamer clearview will not spray water
Did the gasket on the bottom of the water tank come off and is either missing or sitting in the hole where the tank sits? It needs to be on the tank.
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Posted on Aug 10, 2008
  • 29 Answers
SOURCE: Bissell carpet cleaner
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Oct 15, 2013 | Bissell 1697W Powersteamer Pro Upright...
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
ROLLER BRUSH NOT WORKING (BISSELL POWERSTEAMER PRO DELUXE )
The belt may be broken. Follow the link below to belt inspection video on www.bissell.com.
http://www.bissell.com/VideoRating.aspx?id=1555
Oct 05, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Not spraying or picking up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bmv,
Feb 02, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Will not spray water
That means that you need to replace the pump belt. Her is the belt you need and the manual:
Bissell 1697 Proheat Belt and Manual
Jan 10, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
could be a few things.. take the lid off the tank and try spray.
did you fill the bladder and not the outer tank.. rubber on bottom of tank still there.. releases fluid it you depress the x shape center..
hot water. prime from hose without a tool on it by holding the hose lower than the tank.. put in on a work bench.. hold spray trigger and turn on machine.... read my other posts as well
Oct 23, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Not putting out water
I had the same problem with mine and it was an easy fix. If you remove the soap holder without putting the selector dial to "water only" you will lose the prime in the hose that goes to the water chamber. It takes a few minutes of pulling the water trigger to regain that prime, but it will come back eventually. Easiest fix, of course, is to always remember to dial to water only when you need to add cleaning solution..
beth
Jun 02, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
289 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
