Question about AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI MPEG Divx Xvid HDD TV MEDIA PLAYER fr SD USB external hard drive
I pressed the hd option in the set up menu and the screen went blank and a message no signal came up. any suggestions
First please excuse my english...I had the same problem and manage to fix it. Just remember that nothing is broken, the problem is you dont see what you are doing. First unplug your nbox and remove sd card or usb disk. then folow thease step. 1-plug the unit and press power. It is not possible to know if the unite is on... 2-press enter 3-press the down arrow 7 times 4-press enter 5- press left arrow 6- press enter. if it dont work try again and again. You have to undo what you did and put the unite back on the good setings. good luck
Posted on Mar 16, 2011
  • 124 Answers
Try pushing the av or vga buttons also is it hooked up thru hd connection or standard av connection if it is in standard av hd option wont work
Posted on Mar 06, 2011
We have a Phillips plasma tv and the picture pixelates randomly and freezes for about a second and sound breaks also. We have had everything checked and have been unable to find a solution. The latest...
In my openion, Its problem of hardware in your TV and signal processing circuits are involved. It might be problem of Firmware (programe to control the performence over all) Philips can advise you better in this regard.
Aug 01, 2008 | Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
How do you tune in a sense 51 - 19dvdw tv to channels
First check your aerial.
If other devices such as PVRs or other TVs can receive a signal then the Sense 51-19 should be OK also
Turn on the TV.
Press the "TV/.AV" button until the letters "DVB" (Digital Video Broadcast) appear on top right of screen.
Wait until patterned blue screen is displayed and the message "No Signal" is shown.
Press "SYS MENU" 3 times
"General Menu" should be displayed with Language option in highlight.
Press the "CH+" button once to move the highlight to the "Reset" option.
Press the "TV/TXT-DVB MENU" (this has the letters "SET" engraved on the button itself.
The TV will mute and a sub-menu will be displayed in the top left of screen.
Use the "CH+" or "CH-" to scroll to the desired option.
Cheers
May 23, 2012 | Televison & Video
I have a 32 in HD Emerson for some reason last night I was watching a show on Direct TV when the TV went blank . I was instructed no signal so I followed the promptsand it got signal but all I have is a...
Georgine you should have a button on your EMERSON remote that says input or source.
Press that button and a menu should come up with a list of options
use the arrow keys in the center of the remote to highlight VIDEO
Press enter or the circle button in the very middle of the remote
Dec 03, 2010 | Emerson Televison & Video
How do I remove the Hd compatibility message from top of screen?
Go in ur tv menu go to Option go down the menu check the Program Title Dsiplay pick no.That should take away the HD signal sign.But some tv must have that HD sign,to tell u it in HD programings.
Apr 03, 2010 | ViewSonic VPW425 42 in. Plasma HDTV
Screen is blank after (accidently) setting HD Res from 480 to 720
Followed the manual to return to the Default settings, using the remote "in the blind" pressing the arrow and Enter buttons, hoping I hit the right menu button. I did. Case solved. Thanks
Mar 18, 2009 | Televison & Video
Multimedia issue with the Razr V3
While you have already compared settings on the phones, check out these settings that are often overlooked regarding the Internet connection, and not just the messaging portion.
Run through the list, and if it all matches, you should be all set.
From the standby screen, press the Menu Key.
Scroll to "Settings," press Select.
Scroll to "WebAccess," press Select.
Scroll to "Web Sessions," press Select.
Scroll to "Cingular MMS" press Menu.
(if not there select "new")
Scroll to "Edit," press Select.
Validate the following parameters:
Homepage: http://mmsc.cingular.com
Service Type 1: HTTP
Gateway IP: 66.209.11.32
Port 1: 9201
Domain 1: leave blank
Service Type 2: WAP
Gateway IP 2: 0.0.0.0
Port 2: 0
Domain 2: leave blank
DNS 1: 0.0.0.0
DNS 2: 0.0.0.0
Time out: 5 minutes
CSD no 1: leave blank
Username: 1: leave blank
Password 1: leave blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: leave blank
User Name 2: leave blank
Password 2 leave blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: wap.cingular
User Name: WAP@CINGULARGPRS.COM
Password: CINGULAR1
Press Done.
Press Exit.
Press Back
Press Back.
Scroll to "Messaging," press Select.
Press the Menu key.
Scroll to "Inbox Setup," press Select.
Scroll to "MMS Message Setup," press Change.
Scroll to "Server Info," press Change.
Scroll to "MMS", press Menu key.
Scroll to and select "Edit".
Validate the following settings:
Service Name: MMS
Server Name: http://mmsc.cingular.com
Web Session Name: MMS
Dec 13, 2007 | Motorola Mobility RAZR V3
AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI MPEG Divx Xvid HDD TV MEDIA PLAYER fr SD USB external hard drive Logo
460 people viewed this question
Top AGPtek Televison & Video Experts
Sam Bedggood
David Payne
David Payne
Are you an AGPtek Televison and Video Expert? Answer questions, earn points and help others
