Question about Panasonic Heating & Cooling
COMPRESSOR NOT WORKING - Panasonic Heating & Cooling
Check the start capacitor.
Posted on Jul 09, 2008
Compressor not working after vacuuming condenser coil
You either have a bad PTA relay or inverter board. Ohm out the windings on the compressor first to make sure the compressor is okay
Feb 24, 2014 | General Electric GDSL0KCXLS GE Energy Star...
Is the external overload connect to the nurture line can protect the compressor?
if your compressor is shorted to ground then you need a new compressor. if you need help finding what compressor part# you need let me know. The external overload is there to protect the compressor from overheating, but if it doesnt work there is no protection causing compressor to possibly short to ground.
Nov 18, 2011 | True T-49 Side by Side Refrigerator...
My air compressor started making a funny noise from the motor, and it doesn't build up air as fast as it used to. what do you think happened?
the compressor itself has 2 reed valves in it.one works on suction pressure and the other from the pressure generated from the compression stroke of the comp motor.If the valves are weak, they may still work for awhile. The compressor for an air compressor is what is known as an open compressor or semi hermatic. Just means it can be worked on. Those valves are replaceable and much cheaper than a new compressor.
Dec 06, 2009 | Air Tools & Compressors
My compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
1994 rodeo a/c compressor will not come on.
hot wire the compressor to make sure if it is working or not. If all the fuses are working and the compressor is not running then your compressor is defective.
Jul 03, 2009 | 1999 Isuzu Rodeo
Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
May 03, 2009 | Refrigerators
Toyota Camry 95 V6 XLE Compressor
THE A.C COMPRESSOR BELT ALSO RUNS THE ALTERNATOR.AS OF YET THERE IS NO PULLEY U CAN INSTALL TO BYPASS THE A.C COMPRESSOR.SO YES YOUR A/C COMPRESSOR MUST TURN IN ORDER FOR THE ALTERNATOR BELT TO TURN.CALL AND A COUPLE OF ESTIMATES
Apr 29, 2009 | 1994 Toyota Camry
2003 1500HD Crew Cab - Compressor stopped working
the ac system has a low pressure switch when the unit is low on freon the compressor wont work . this is to keep the compressor from burning up. have your freon level checked.
Dec 19, 2008 | 2002 Chevrolet Silverado 1500HD
Why did you change the mother board? Was the compressor working before the change? If it was, then you need to check the new board and see if there were any wires that need to be cut when it was installed. If it wasn't running before the board change then you might try the overload on the compressor first. Also it should be checked with a compressor checker to determine if the comp is at fault or not
Sep 06, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Compressor will not work
  • it may be the compressor, check the temperature of the compressor when it has been running for a while. if it is too hot to touch then it is going bad. the compressor should only get warm not hot.
  • the start switch will also kick out if the compressor is drawing too much amps (even if cold) witch would also be a sign of a bad compressor.
  • another thing that could cause this problem is if the coils under the machine are dirty or the airflow is blocked. this will cause the heat to build up in the compressor and kick the start switch off.
  • compressors don't last as long as they used to.
Jun 29, 2008 | Frigidaire Refrigerators
Heating & Cooling Logo
63 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
