Hisense air conditioning unit displaying FC, what does this mean?
  • 2,133 Answers
FC Outdoor low pressure drop. Check your gas pressure. It should be 60 PSI in ambient temp of 98 degree Fahrenheit.
Less gas pressure not only due to gas leak. But also indoor coil and air filter chocked . Service the unit and test again. Helpful?
Posted on Jan 02, 2011
In 'FC', 'F' stands for Filter
Posted on Nov 11, 2011
  • donchin123 Nov 11, 2011
    'F' in 'FC' stands for Filter
  • donchin123 Nov 22, 2011
    my solutions has not been fully published
    New Friend:
What is mean by refrigirent
Posted on Jun 07, 2013
According to me FC means Fan Control . Check your Fan Control .
LG Air Conditioner
Posted on Apr 02, 2014
What does E5 mean on Soleus Air dehumidifier?
hi Randal.
this is all i could find on the internet.
Your dehumidifier has sensors to monitor for various conditions that may prevent the unit from operating in a normal manner
problem,the led display is showing e5, possible cause,over current protection..solution.unplug for 10.minutes then turn on the unit and if the e5 is still showing contact customer services or a dealer.
you could try this link as well to see if its of any help to you.
What does E5 mean on Soleus Air dehumidifier Google Search
Dec 03, 2017 | Soleus Dehumidifiers
The tv turns on and stays on the hisense screen is it broken??
It is sort of broken. See if you can manually reset the unit to conditions when brand new in box. Try unplugging unit. then push in and hold the power button for about a minute. then reconnect to power and turn on. If it still does the same, , the main board is at fault.
Feb 05, 2017 | Hisense Televison & Video
WHY IS MY AIRCON DISPLAY E1 ?
THIS MEANS THAT THE ROOM THERMISTOR ( A DEVICE CONNECTED TO THE THERMOSTAT THAT DETECTS THE ROOM TEMPERATURE IS SHORTENED OR DEFECTIVE AND YOU NEED TO HAVE YOUR AIR CONDITION SERVICED
Jan 31, 2015 | Heating & Cooling
Beeps and flashes FC
The "FC" error code means "Communication error between boards".
Check the "J2" harness, ohm wires end to end.
If the harness is fine then the display board is defective.
Here is the part to order.
Jan 24, 2013 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I hav bought a split unit of hisense 2 monthsback i dont how but since 2 days even if i put off the unit with remote there is "FC"sign lit on the unit which does not go off ...the unit model no...
Hi and welcome to FixYa, I am Kelly
Your not going to hurt it by using it with the FC being displayed. FC = Filter Clean. This will appear after every 100 hours of use. Your supposed to remove the air filter and wash it. Usually you have to push the right button on the control panel (often labeled mode) and either the UP or DOWN temp arrows for 3 - 5 seconds to get your display back to normal. Pushing the Up arrow at the same time as the MODE switch should get you a Fahrenheit Display. Pushing the Mode button and the Down arrow at the same time should get you a celcius Temp display.
( I am pretty sure you have to do this on the unit and not with the remote. )
Why manufacturers DO NOT put this information in their user manuals is a bit baffling to me as a service tech. HiSense is not the only one that omits this information.
Should the steps above not resolve your FC display call your HiSense Distributor and ask them how to you reset the Filter Clean (FC) Display. They will be able to tell you over the phone.
Like I said in the beginning your not going to hurt it by using it with the FC being displayed. If you change the temp up or down by 1 deg you will see the display for a few seconds then the FC will re-appear until you reset it.
This is the AU Contact data:
Phone: 1800 HISENSE (1800 447 367)
Fax: .
Email: enquiries@hisense.com.au
Email them and ask how to reset the FC on the display. Remember you will get this display every 100 hours of operation.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Heating & Cooling
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
I need to know what the buttons do and what the display symbols mean on remote control type Y 512F for my air conditioning unit.
can you help me the buttons do for my air conditioner 8_26_2012_12_08_39_pm.jpg the buttons are mode,fan,sleep,swing,air,light,T-on.T-off (please help me)
Nov 23, 2009 | Heating & Cooling
Air Conditioner Error code?
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Mar 16, 2009 | Haier Energy Star ESA3183 Air Conditioner
Remonte controls for Hisense air condition
hi , you can bring a universal remote and this one can work for many air conditions look at the codes for the kind of ac.
Feb 16, 2009 | LG LSC091PMA Split System Air Conditioner
Heating & Cooling Logo
3,514 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
