Cars & Trucks Logo
Posted on Jan 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Took spark plugs off to replace and didn't write down the order in which they came off. Now we need the firing order; 1986 Dodge Diplomat, 318 V8 2barrel. Can you help?
ZJ Limited
Level 3:
  • Dodge Master 17,989 Answers
  • Posted on Jan 11, 2011
ZJ Limited
Dodge Master
Level 3:
Answers
17989
Questions
0
Helped
14453565
Points
60858
1986 Dodge Diplomat 5.2 liter V-8 2-bbl
Hope helps (remember to rate this answer).
Anonymous
Level 2:
New Friend:
  • Expert 45 Answers
  • Posted on Jan 02, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
45
Questions
0
Helped
7684
Points
129
Firing order dodge 318 =1 8 4 3 6 5 7 2
I keep asking the same question for a 1971 dodge 318-1 v8 engine and get every year but what im asking
The firing order for a Dodge 318cid/5.2L is 1-8-4-3-6-5-7-2 clockwise rotation.
Cylinders are numbered like this.
Pass side 2-4-6-8 front to rear.
Driver side 1-3-5-7 front to rear.
The firing order is probably forged into the intake manifold. Number one tower on the distributor cap is the one facing the number one plug or the driver-side headlight.
Distributor rotor at Number 1 plug terminal points to front intake bolt on left side of engine.
1helpful
I have a 1975 winnebago from dodge Someone messed with the spark plug wires I need the fireing order and how the wires go on the cap Dodge winnebago 1975 v8
You could have 3 different engines in that rig.
The firing order is 1-8-4-3-6-5-7-2 for most Dodge 8 cyl engines.
And the odd cylinders are on the driver side.
The small block engines ( 318 ) have the distributor in the back, and the big block engines ( 360 440 ) are in the front.
The rotor on the big blocks turn counterclockwise. The dist cap is usaully stamped with cyl 1 as a starting point.
2helpful
I need to know where the plug wires go.from spark plug to distibuter cap on a 1986 4.1 coupe deville(cad.)
FIRING ORDERS NOTE: To avoid confusion, remove and tag the spark plug wires one at a time, for replacement. If a distributor is not keyed for installation with only one orientation, it could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your book to reflect how your engine is wired. Fig. 1: GM (Cadillac) 250 (4.1L) V8 GM (Cadillac) 273 (4.5L) V8 Engine firing order: 1-8-4-3-6-5-7-2 Distributor rotation: counterclockwise 85872009.gif Fig. 2: GM (Oldsmobile) 307 (5.0L) V8 GM (Oldsmobile) 350 (5.7L) V8 w/EFI Engine firing order: 1-8-4-3-6-5-7-2 Distributor rotation: counterclockwise 85872009.gif Fig. 3: GM (Buick) 252 (4.1L) V6 Engine firing order: 1-6-5-4-3-2 Distributor rotation: clockwise 85872010.gif Fig. 4: GM (Cadillac) 368, 425, 472, 500 V8 Engine firing order: 1-5-6-3-4-2-7-8 Distributor rotation: clockwise 85872011.gif Fig. 5: GM (Cadillac) 429 V8 Engine firing order: 1-8-7-2-6-5-4-3 Distributor rotation: clockwise 85872012.gif prev.gif next.gif
13helpful
2answers
I need the firing order for the wires to the distributor cap.
there are several engines--please pick yours.
V8-318 and 360 EnginesEngine Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Clockwise:
V8-400 and 440 EnginesEngine Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Counterclockwise:
V8-383 and 44 EnginesEngine Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Counterclockwise:
2helpful
Some of the spark plug wires on my 1991 Dodge Dakoa Sport V8 inadvertantly got removed from distributer cap and I'm not sure I put them all back in the correct order. If anyone can provide information on...
For the 1991 Dodge Dakota 318 cubic inch = 5.2L V8
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
..........(back)...........
|...8...|..........|...7...|
|...6...|..........|...5...|
|...4...|..........|...3...|
|...2...|..........|...1...|
..........(front)
Distributor:
............3
....4..............6...
.......................(+)-screw: rounded-end of Cap
8......................5
(+)-screw: square end of Cap
.....1...............7
..............2
.........(front)
Rotation: Clockwise
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
1helpful
Spark plug diagram
if it is a V8 318 engine the firing order is 1-8-4-3-6-5-7-2.....cheers
1helpful
86 dodge 250 v8-318 no fire at spark plug, will not start
did you change the main coil and coil wire?if so then check the ing resistor and then the computor box
7helpful
2answers
Need firing order on a 1996 dodge ram v8
The order should be stamped on your intake manifold right under the air cleaner.
My '97 1500, 5.2, 318 firing order is 1-8-4-3-6-5-7-2
Hope this helps
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
