Question about Panasonic Technics SL-DZ1200 Turntable
I have a SL-HM42, it has a small flat white plug on it and I'm not sure how to hook it up. Am I missing something?
My guess is that the white is ground, the next one live power, and the other four are the speaker cables. Theoretically, you should just need to hook it up to a 12-V power supply, the speaker cable to an amplifier, and you should be good to go
Posted on Dec 04, 2011
  • LLLLL Apr 06, 2012
    Ok, that wasn't quite the fix...if you look at it head on, so the two "bumps" are at the top and you're looking into the connector, the white wire on the right (the left most too should be empty) is for the right speaker, not sure what the second one from the right is, the third from the right is the left speaker, then power ground, then 12 V +, then ground, then two blanks. I've gotten my record player powed, although I'm having difficulties corresponding the left/right ones to my speakers. All I'm getting (sending it through a different amp via speaker wires) is a popping sound or static. Anyone have any ideas?
    -LLLLL
I'm trying to work out the same thing too. The stereo unit that came with the sl-hm42 stopped working recently and I'm trying to work out a way get the record player going again. By the looks of things I'm going to have to invest in a pre-amp to boost the output of the record player but that will be no good unless I can work out what each of the wires do....
Let me know if you work it out yeah?
Also, just to check, does your flat white plug have 6 wires?
Posted on Feb 07, 2011
Recently purchased used Panasonic SL-HM42 turntable. Works, but turning a little slow on 33rpm (30-31rpms) says DC Servo System on the front. Don't see any set screws on bottom. would like to get platter...
How to tweak the playback speed on Panasonic SL-HM42 turntables
You will need:
  1. 1x small Philips screw driver
  2. 1x small flat-head screw driver
  3. An ear for correct pitch and a little bit of DIY skill!
Step 1 - Remove the wooden base plate
After ensuring that you've removed the the rubber turntable slip mat and securely docked the turntable arm, carefully flip the turntable over onto its lid to expose the wooden base plate, as per below.
Using the small Philips-head screw driver, remove the screws holding the wooden base plate in place, then gently lift the base plate off the turntable.
Step 2 - Expose the pitch adjustment screws
Once the wooden base plate is removed, you will see the speed-controller circuit board on the right-hand side.
To expose the the two speed/pitch-control screws, firstly remove the screw holding the speed-controller circuit board in place, then gently lift the circuit board up on the free side.
Step 3 - Correct the turntable playback speed and pitch
The easiest way I found to correct the playback speed was to flip the turntable carefully back into the original position, allowing the speed-controller circuit board to hang free as shown below.
Next, play a record that you know well and are able to tell when the speed/pitch is correct (assuming you have an ear for correct pitch, that is!), then at the same time using the small flat-head screwdriver, gently turn the speed adjustment screw(s) to adjust the playback speed up or down until the correct playback speed and pitch is achieved (or at least until it no longer annoys you ;).
Turning the screws clockwise (to the right) will increase the speed/pitch, and anticlockwise (to the left) will decrease the speed/pitch.
NB - Both screws allow for fine pitch control, so if the second is already at maximum speed, you can use the first screw for additional speed.
Step 4 - Reassemble the turntable again
When you're happy with the speed of your turntable, remove the record, the mat again & locking the turntable arm, replace the screw holding the speed-controller circuit in place (as per Step 2) and then finally replace the screws holding the wooden base plate, as per Step 1.
Happy listening!
Aug 29, 2013 | Audio Players & Recorders
Panasonic SL-HM42 turntable runs a bit too slow on 33rpm. Hasn't been played in a while. How do I the plate off to check the belt?
Most turntables need you to lift of the matt and then round the spindle is a horseshoe clip which you need to take off.
Aug 29, 2013 | Sony PS-LX250H Turntable
I just bought a 40"
you are trying to hook up composite to component. the component green is your y video or black and white getting b and w proves your component is working plug up red and blue make sure your dvd player has component out have to use seperate audio for component
Jul 18, 2011 | Televison & Video
Hooked up lap top to samsung tv #LN-T2632H using HDMI cable i get picture but no sound what can i do
may need to run a small cable that would plug in for the head phones port of your laptop to the back of the tv's audio port red & white much like one that is used to hook up an mp3 player's to the stereo... would have a small male plug size of head phones and the other end male audio jacks white & red .... not sure why the hdmi isnt providing the sound but think it will fix the issue... csn send a picture of what you need if your not sure what i'm referring to.
Mar 07, 2011 | Samsung LN-T2632H 26 in. LCD HDTV
I got a panasonic atomotive turntable - ser.no. SL-HM42. I require a needel for above
Check online. There are plenty of places that sell needles for turn tables!
Dec 03, 2010 | Panasonic Audio Players & Recorders
How do you take the wii and hook it up to the tv?
You take the cord that came with the Wii, has a small plug one end and 3 plugs other end, rred,yellow and white. Plug th small side into back of Wii and the 3 color cords into the matching slots either on the front or back of your tv.
Nov 13, 2010 | Insignia Televison & Video
I just changed out me screen on my dell inspiron 1000, and now it won't turn on at all?
Please make sure that you have reconnected all connectionpoints, and if there is a grounding strap - a flat woven wire connected to the monitor and the laptop's motherboard - ensure that it, too, has been tightly connected.
-a.
Nov 23, 2009 | Dell Inspiron 1000 Notebook
Tried hooking up the DVD player and get no sound & the color is really bad. I have the red, blue & green hook up am I missing something?
You have component cables from your description. Make sure that each one is in the right slot on both the DVD output and the TV input. As for the audio, the component cables do not carry audio, so you need to hook up audio out from the DVD player to audio in on the TV. Usually red and white RCA jacks for audio plugged into their respective color coordinated ports. Good luck and I hope this helps.
Oct 27, 2009 | Haier DVD101 DVD Player
Panasonic automatic turntable model sl-hm42
I'm having a similar issue - except my panasonic sl-hm42 platter is moving too slow on 33 1/3 settings (don't have any 45's to try). It's a DC model, so I would think there would be some kind of pitch control settings or screws somewhere on it but I can't seem to find them.
Does anyone know if it's possible to adjust the pitch on this model turntable? Thank you!
Oct 25, 2008 | Panasonic Technics SL-DZ1200 Turntable
Panasonic Technics SL-DZ1200 Turntable Logo
550 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
