Question about Frigidaire FGR641F Gas Dryer
How do I take the top or the front off so I can check the drum? something is stuck in the drum and is making it drag and has an awful noise.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Here is a video to show you how to open the dryer. Use a putty knife instead of a flathead screwdriver.
Posted on Jan 02, 2011
Dryer is making an awful sound like a coin is stuck in drum???
On most dryers, the top pulls off straight up. Then you can see inside the housing, there are screws that hold the front on from the inside. If you take those out, the front comes off and you can check the drum seal area in the front and see if anything is there. Most use a set of guides to keep the drum aligned and those can wear out, they look like nylon blocks. Make sure you unplug it first.
Mar 09, 2016 | Dryers
Very loud during cycle
most top loading machines have clips that attachthe top to the front, pry up on top with small pry bar or screwdriver. if noise is a banging noise, you may have a spring that broke or came off underneath machine. i would check under washer before removing top.
Nov 10, 2013 | Maytag Washing Machines
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
Maytag performa electric dyer makes dragging noise drum turns but acts like something catches and makes a dragging or scraping sound
assuming nothing is stuck around drum pull off the front and check the fan. If it is noisy for a few seconds after you stop the dryer then the fan may be stripped on motor shaft. while off you can check the front glides and the rear rollers
Nov 17, 2010 | Maytag Neptune MDE4000 Electric Dryer
Money stuck inside drum making noise
The easiest way to access the area between the inner and outer drums is to take the front off. Instead of something being in the drum making the noise it may be the front felt pads that the front of the drum turn on. It makes the same noise. They are replaceable.
Jun 19, 2010 | Washing Machines
My washing machine is making an awful noise when its changing direction on the drum motion and changing programme. its sounds very much like some sort of ball baring has come loose. - what doi I do please...
put the machine onto drain position if it still makes the noise it is something stuck in the pump check and clear filter if makes noise only when drum turning then is highley suspect bearings have failed.
Jun 02, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My dryer is making a scratching noise like something is stuck behind the drum toward the front of the dryer. Any help?
The drum has a seal between the drum and the front panel of the dryer. You would need to remove the top then the front panel to gain access to replace or maybe clean the seal
Mar 30, 2010 | GE Profile Prodigy DPSR513GA Dryer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Something rattling under the drum
Strangely enough, I found the problem to be in the motor. If the noise becomes pronounced during the high speed spin cycle, then that is the problem. I had a repairman out for mine and they wanted to replace the drum, however when I took off the back and removed the belt, I could turn the drum separate from the motor and could hear that the problem was in the motor bearing, not the drum. Hope this helps.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Dryer Makes a loud noise
hi you might have something stuck inside the grill at the back, mine made an awrful noise until i removed a bone out of a bra lol (dran things)
Sep 22, 2008 | Dryers
Frigidaire FGR641F Gas Dryer Logo
65 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
