Question about Sta Rite Aboveground Swimming Pool Pump 34 Horsepower ()
Motor making wining noise. Only 2 years old. - Sta Rite Aboveground Swimming Pool Pump 34 Horsepower ()
    President:
  • Sta Rite Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 02, 2011
Danby wine fridge making noise
If I checked out the right video it sounds like a fan motor. After a fan motor heats up and with age the fan will leak a little oil, the oil will become to thin and not cote the bearings well enough. It sounds like the fan trying to start back up after stoping. I would track down the fan motor and replace it.
Apr 09, 2014 | Danby DWC283BLS Wine Cooler
FAN MOTOR MAKING NOISE SLOWING UP BEEN RUNING ABAUT 6 YEARS FIRST PROBLEM EVER
The motors are filling up with dust and dirt that's why it getting noisy and slowing down. You can spray chemicals to the motor shaft like WD-40 to loosen the dirt that has accumulated and make the motor run smoothly again. Further, you can put a bit of oil to the motor shaft to make it run smoother for a longer time. To do this, you'll have to disassemble the motor to expose the motor shaft (a piece of metal that connects the propeller to the motor coil).
Apr 02, 2014 | Danby DWC283BLS Wine Cooler
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Temp. is on automatic settings for "Red Wine" but fluctuate between 51-59 degrees, not to mention makes all sorts of noise (common refrig. noises) is this normal? Haier 35 bottle wine refrigerator
temps will fluctuate. depending on door openings and defrost cycles.no abnormal noises heard on the ones ive worked on but appliances tend to be noisier then they were. if less than a year old have an authiorized servicer go out and look at.
Sep 16, 2009 | Haier Refrigerators
Wine cooler makes noise and runs hot
The price looks fine for my area its about a 3 hour job done properly. you should consider a new wine cooler and cut your losses because if their only replacing the compressor they should be replacing the cap tube and liquid drier if the cap tube is not replaced could be a waste of money
Tom
Jun 17, 2009 | Danby DWC283BLS Wine Cooler
Haier Wine Cooler motor died
Yes, those motors shoudl be pretty standard stock items at any local appliance parts supply house found in the yellow pages.
You might also try lookinmg under "motors and controls" in the yellow pages. If you get it locally like that then you can physically compatre the old one with the new one to make sure it is indeed the same part.
Thats better than an online link with just pictures.
Jan 27, 2009 | Haier BC112G Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Non stop compressor?
these units have a condensor cooling fan in the rear it appears that yours may be seized up.
Regards
Advisor
Nov 10, 2007 | Danby DWC283BLS Wine Cooler
Sta Rite Aboveground Swimming Pool Pump  34 Horsepower () Logo
65 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
