Question about Gateway Computers & Internet
2WIRE 2701HG-G WHERE IS THE WPS BUTTON?
5 Suggested Answers
SOURCE: port forwarding? 2wire 2701hg-T
access your gateway homepage by opening your internet browser and typing this on the address bar: 192.168.1.254/management. then key in your system password and click on Settings under Firewall. there's option#2 (allow individual applications), click on "Add a new-user defined application", input the data and click submit another way is to enable DMZ plus mode. that option would actually make all the ports open. use this if option#2 is not working. after making the above changes refresh your router, just unplug then replug it from the power.
Posted on Feb 19, 2008
  • 17 Answers
SOURCE: Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Posted on Feb 28, 2009
  • 117 Answers
SOURCE: 2701HG-G firmware upgrade
Yes you can upgrade by buying the home networking package. It's $80. Otherwise you will have to upgrade your service. They're giving these modem/routers away free with upgrades.
or Found it...looks like my capped rate is 3008. that is their profile rate they've limited me to, or the maximum my connection can get.
twdsm.attenuation_ds = 61.03; % Only calculated during training
twdsm.attenuation_us = 31.50; % Only calculated during training
twdsm.margin_ds = 11.00;
twdsm.margin_us = 7.00; % Only calculated during training
it means you have down stream attenuation of 61.03%, up is 31.50%...
Posted on Aug 29, 2009
  • 381 Answers
SOURCE: I am trying to set
Hello pbufordjr,
WPS stand for Wi-Fi Protected Set-up . According yo Wikipedia "The goal of the WPS protocol is to simplify the process of configuring security on wireless network, If your 2Wire router is equiped with that function it would be the BIG button on the bottom front of your router Look at this advertisement from 2Wire http://2wire.com/movies/pages/112.swf
Posted on Aug 04, 2011
I am trying to set up my hp printer and I am trying to find the wps button on my 2wire router that the set screen is telling me to press. But I don't see one on it. Does 2wire support WPS, what ever...
Hello pbufordjr,
Aug 04, 2011 | 2wire (2701HG-B) Wireless Router
I want to know if my 2wire 2701HG-B supports WPS or AOSS? I'm trying to connect my laptop to my wireless printer but it goes through a Wireless Network which is my 2wire router obviously. If my router...
As long as you do not have your laptop set up on teh 2701HG-B's DMZ everything should work. I have the 2701HGV-B, almost the same except my can do VoIP, and I have my laptop running wirelessly and I can connect to the network printer.
Make sure the printer has a static IP address for your local LAN, which should be in the 192.168.X.X scope, or the printer will change IP addresses every time it resets and that will cause you to lose connection to it from the laptop.
As for WPS, there should be a sticker on the side of teh 2-Wire that has a 6 digital key number, all numbers no letters, that will be the WPS key.
Hope that helps.
Jun 04, 2011 | 2wire (2701HG-B) Wireless Router
Where is the wps button on my 2wire router?
Is your "router" a Gateway? Does the front of it look like this pic?
If YES, the WPS isnt obvious. Touch the WiFi logo. Thats the button
Apr 30, 2011 | 2wire.net
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
Trying to connect to sony blu-ray wireless where
Certain routers will not have a wps button on it...
You can go for the next options in your bluray...
You will have options to enter network key...(this is wireless network password)
Or you can configure using PIN number...(an 8 digit number printed at the bottom of wireless router)
But if u configured using wps or pin number, then the wireless settings on your router will get sync with bluray player... All your other wireless devices like laptops and iphones and gaming system will lose their connectivity to the wireless router...
so it is advisable to type the security password of your router in bluray player...
Nov 29, 2010 | 2wire (2701HG-B) Wireless Router
2wire 2701HG-S Embarq to AT&T
that is typically a bad username in the modem, you will have to put there temp user name in for registration for the DSL. and after that you can put the username into the modem that you created during the registration process. Should be taken care of.
May 15, 2009 | 2wire Computers & Internet
Computers & Internet Logo
2,565 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
