Question about Roper RS25AEXLQ Side by Side Refrigerator
Water leaking from refrigerator
Water drips from the round tube in front of the freezer into a drip pan. 1. How do I get the dripping to stop? 2. How do I get the drip pan out to empty/clean it?
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If you just want to clean it you may can access it from the rear behind the cardboard backing. If it's overflowing your water filter may be stopped up or you may have had an excessive amount of frost one time.
Posted on Aug 14, 2009
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
During the defrost cycle our refrigerator leaks water from the freezer side out the front into the floor of the kitchen. Where could it be coming out and what will fix it?
The water from the melting ice during defrost should be guthered from the drip drain pan which is under the evaporator pipe coil and is passing though the drain tube which is conected to the dip pan and should end out on the back of the fridge to the compressor to evaporate. The problem posibly is that the drain tube is goggle either from ice or from dirt or both and the water since it can not end to compressor it overfrow from drip pan inside the freezer. So you can clean the drip pan and drain tube using a wire rod and problem will be solved.
Sep 13, 2011 | Refrigerators
There is evidence that my refrigerator has leaked a significant amount of water . Currently there is no water dripping anywhere. The floor is dry. When water fills the ice maker there is no leak. When...
leaks like this are often during the defrost cycle . the amount of water is about a cup or 2 . .. ck the tube to the pan and ck the pan for cracks... you can add water to ck it . they do crack as this is a hot area . . hope this helped **** .
Jan 05, 2010 | Refrigerators
Freezer leaking into refrig compartment how do i
need to know the brand or call me at 813-270-4029
Aug 22, 2009 | Refrigerators
Water leaking from under refrigerator
Analyzing the likely source
Instructions
STEP 1: Move the refrigerator out from the wall and look for the location of the leak. STEP 2: Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem. STEP 3: Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker. STEP 4: Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking. Fixing a condensation problem
Instructions
STEP 1: Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely. STEP 2: Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly). STEP 3: If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls. Fixing a drip-pan problem
Instructions
STEP 1: Pull off the grill that runs along the bottom of your refrigerator. STEP 2: Locate the drip pan, using a flashlight if necessary. The pan should be sitting on top of a set of black condenser coils and directly below a drain tube that carries water from your freezer when it is in defrost mode. STEP 3: Place the drip pan in your sink and fill it with water to test for leaks. If it leaks, order a replacement from your appliance dealer. STEP 4: If the drip pan doesn't leak, clean it with warm, soapy water, then reinstall the pan and the refrigerator grill. Fixing a clogged defrost drain
Instructions
STEP 1: Locate the defrost drain. It should be a round hole or a channel running under the vegetable and fruit bins in the refrigerator or along the floor of the freezer compartment. STEP 2: Inspect the drain for clogs and remove any debris. If necessary, use a small screwdriver to break up debris that's trapped in the drain hole. STEP 3: Fill a meat baster with hot water and force it through the drain to make sure the clog is gone. If the drain is operating properly, the hot water will fill the drip pan. Fixing a leaky ice maker
Instructions
STEP 1: Pull the refrigerator away from the wall and locate the copper water-supply line. It runs from the house water line to the refrigerator water-supply valve. (To get to the supply valve, you may have to use a screwdriver or a nut driver and socket to remove your refrigerator's back access panel.) STEP 2: Inspect the copper supply line, the supply valve, and the plastic supply tube that runs from the other side of the supply valve to the back of the ice maker. STEP 3: If a connection is leaking, tighten it with an adjustable wrench. If either the copper supply line or the plastic supply tube is leaking, you need to replace it. STEP 4: Turn off the water supply. The valve may be under the kitchen sink or connected to a cold-water pipe in your basement. STEP 5: Remove the faulty line and take it to a hardware store to get an exact replacement. STEP 6: Install the new line, tighten the connections with the adjustable wrench and turn the water back on. Overall Things You'll Need
Meat Baster
Adjustable Pliers
Adjustable Wrench
Soap
Nut Driver And Socket
Replacement Parts
Flashlight
Screwdriver
Who Can Help
Find Prescreened Appliance - Repair or Service Contractors at ServiceMagic.com
Overall Tips & Warnings
To keep door gaskets clean and supple, wash them twice a year with warm, soapy water, then coat them with a light film of petroleum jelly.
Some refrigerators have an internal defrost drain that is meant to be serviced by a professional. If you can't find your drain, call a pro.
To prevent possible electrical shock, always unplug your refrigerator before working on it.
Put carpet scraps or another soft material under the front legs before pulling your refrigerator away from the wall. Otherwise, the legs could damage the flooring.
Aug 05, 2009 | GE Refrigerators
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Interior water leak on model ET18PKX6HB1 whirlpool refrigerator
The drain is clogged up. Check the clear plastic line that goes from the back to the drip pan on the bottom of the unit.
Mar 30, 2009 | Whirlpool Refrigerator Inverter Box -...
Drip pan
the drip pan is built into the bottom and dont come out ,,, check the drain pipe to make sure its still sticking in the pan ,,,, also check the bottom inside of your freezer, drain may be stopped up and causing water to come out front edge of door / larry
Nov 29, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Leaking refrigerator
  • if the drip pan is not cracked or overflowing then it could be that the drain tube that goes to the pan is clogged.
  •  a good thorough cleaning of the freezer should help.
  • also pour a little hot water in the back of the freezer (i take the refrigerator outside and blast it with a hose, but thats just me), this will hopefully melt any ice buildup that may be causing the problem.
  • the tube sometimes runs on the outside of the refrigerator along the back.
  •  either way the tube goes from the bottom of the freezer to the drip pan.
  •  let me know how if you need more help.
Jul 01, 2008 | GALAXY Microsystems 63702 Top Freezer...
Roper RS25AEXLQ Side by Side Refrigerator Logo
319 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
