I have an ideal classic rs360 boiler .the problem i have its been firing up and warming up stairs radiators and not down stairs. i have it flushed out and changed worked ok for a couple of days now its gone back to the way it was. it fires up for 20 seconds then shuts off wait a bit then same again. please can anyone give some clues as to whats happening.thanks Albie.p/s also changed valve.
  • 661 Answers
SOURCE: reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
Posted on Nov 02, 2007
SOURCE: Reddy Heater Model R150A fires up then shuts down
I think most of your reddy heaters need the oriface cleaned
Posted on Feb 23, 2009
  • 188 Answers
SOURCE: Reddy Heater keeps shutting down
I tried to go to and you cannot buy parts on that site anymore. I can get my Reddy Heater parts at
Posted on Mar 06, 2009
  • 43501 Answers
SOURCE: flame sputters
Hey welcome to the world of oil burner service!! :-) Theyare a finnicky beast to say the least. The problem you are having sounds like an air mixture problem. A combustion analyser would be the best tool to have but being that you probably don't have that try this. On the left side of the burner as you are looking at it is an air adjust ment ring and a fine tuning ring. the fine tuning ring is probably all you need to adjust. There is a screw that is usually right behind or near the pipe coming out of the pump and going into the burner. Loosen that and turn the ring away from you just a bit to close off some of the air and you will be fine. The burner is running a bit to lean. If you can see the flame turn the adjustment closed just until the flame color turns from a almost white color to a slightly orange color. Then you should be fine. Good luck!!
Posted on Nov 15, 2009
  • 43501 Answers
SOURCE: I have an ideal standard he30 boiler instaledi
You have a problem that the installer does not know how to fix so they are just stringing you along hoping that you will give up and find some one else or forget about it..
You need to tell them to
1. fix the boiler correctly
2.take it back out and give you a new one at their expense
3. or tell them you will call another comapny to fix it and will give the bill to them to pay.
You did not get what you have paid for... do not pay them any money to come out and troubleshoot the boiler.
The boiler should work as the instructions say or someone did something wrong...
Sometimes it is best to call the boiler company and talk directly to their Tech. Support people.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Posted on Dec 24, 2009
Testimonial: "offerd good advice"
Ideal Logic + Combi C30 not firing up.
Isconnect from the hive ,it has been known the hive thrmostat fails on ideal boilers.
Mar 22, 2017 | Water Water Heaters
I have a ideal mexico boiler
you have sludge in your in your rads need a rad flush to clear it out .
Mar 02, 2013 | Heating & Cooling
I've just moved and the boiler is an Ideal Classic
it should be a fully pumped system , which pumps heating and the hot water i take you have ahot water tank /cylinder for hot water with a 3 way valve on it , hmm set the boiler thermstat to number 5 put you clock /programer to hotwater only,once aday or twice , its down to how much water you need . see if this helps .
Aug 24, 2011 | Heating & Cooling
The pressure started to drop every day and needs to be filled with water(dry fire??). This happened after repositioning of some of the radiators daown stairs after fixing the wood flooring. The...
The operating pressure should be between 12 and 15 psi.It may go up some while in operation.
A pressure loss indicates a leak,you may be able to find the leak by filling the boiler up to 15 to 20 psi,then running it for a while.
Once you have it running check all fittings and solder joints for water leaks,lay a white paper towell down at the radiator conection areas and see if you get any water spots.Sometimes using a soap and water solution and applying it to the joints and connections will help,if you see bubbles thats where your leak is.
You sound like you have a 2 story house,check the upstairs radiators also.
Mar 04, 2011 | Heating & Cooling
Ideal classic boiler no heating only hot water when heating is switched to on there is no sound from system but there is when water switched on. the rads upstairs were warming up but not downstairs now...
Hi it sounds like the pump is not working or diverter valve not working check to see if pump is working on ch mode as well as valve , pump could be stuck ,
Apr 12, 2010 | Heating & Cooling
Ideal classic LXFF not igniting but still giving
ch themistor may be faulty,or divertor not working.
these are the two things that may cause this
Dec 31, 2009 | Jason Natural Cosmetics Jason Forma...
Heating not working properly on my sime super 90 combi boiler
you need 15 lbs water press,bleed air from system, primary must be bad
Mar 29, 2009 | Water Heaters
Ideal c80ff
differential is set too close and water temp set too low.dirty coil can have same result -how old is unit?
Oct 26, 2008 | Water Heaters
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
