Question about JVC RX-6018V Receiver
5.1 surround sound will not work. Only showing digital auto and linear pcm.
    Problem Solver:
  • 4 Answers
You should try pressing the surround on/off button or the speakers on/off button
Posted on Feb 27, 2011
Optical Audio Output Formats for PS3
look in your receivers manual or download it using a google search
Dec 23, 2013 | Kenwood VR-606 Receiver
My component is in LINEAR PCM MODE when it start playing dvd/cd no sound comes out. while in CASSETTE TAPE, it has a sound. i want to know what is this LINEAR PCM, coz i notice, when i turn FM it has a...
LPCM is for digital sources ONLY. Your cassette wouldn't be digital would it? FM, being an internal source on your unidentified receiver CAN'T be wired or configured incorrectly. Crack the manual open and find out how to set the parameters for all the digital inputs, then connect and select an analog input for the tape.
Jun 24, 2011 | Audio Players & Recorders
Pcmcia is flashing and no sound out of our receiver
Check page 31 of the manual regarding PCM versus theDTS settings. Choose AUTO surround mode and that might do the trick. Page 29
If the source is external, make sure it is sedning the desired digital audio format - PCM, Dolby Digital, DTS, etc.
Mar 11, 2011 | Marantz SR-19 Receiver
I have a blue ray Prayer connected to my Panasonic SA-HE100 via a toslink digital audio cable. I don't get 5.1 surround sound. I do get stereo but not 5.1 where the back speakers sound. Any...
hi,
do one thing
1. press and hold DIGITAL INPUT button on the remote( will display AUTO--PCM FIX--DTS FIX)
2. select AUTO among them. and the try
ok
Jan 31, 2011 | Panasonic SA-HE100 Receiver
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Optical input from Sony PS3 Playstation.
Have you tried setting the PS3 on linear PCM output instead of bitstream? The DVR 50 may not say Dolby Digital since the optical cable goes directly from the PS3 to it but you may get the surround channel output you're looking for.
Mar 13, 2017 | Jamo DVR-50 System
PS3 Surround SOund
go to the audio settings, i'm not sure what it was it was called like linear pcm or something like that...it worked for em
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
Ps3 sound setting for Acoustic Solutions tv
i had the same problem with my acoustic solutions astv 3619ws, you have to change the settings to:
linear PCM 2 ch. 44.1 khz
linear PCM 2 ch. 48 khz
linear PCM 2 ch. 96 khz
linear PCM 2 ch. 192 khz
you have to unselect all the other settings.
Feb 06, 2008 | Televison & Video
Bad sound through HDMI
Is it only in Games or Movies?
Try checking the cables. (obvious I know but it must be said).
On the XMB (Cross Media Bar), go to settings on the left. Scroll down to "Sound Settings"
Choose "Audio Output Settings", then "HDMI", then "Auto"
If that doesn't fix it then choose manual and the most basic outputs first;
-Linear PCM 2ch. 44.1KHz
and
-Linear PCM 2ch. 48KHz
Depending on your surround sound setup your could get away with other options as well. Fist determine if your setup is 5.1 or 7.1, DTS or Dolby Digital. Then start with the lower KHz settings and work your way up.
Dec 12, 2007 | Sony Playstation 3 (PS3) Console
JVC RX-6018V Receiver Logo
156 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
