Question about GE PFS22SISSS Stainless Steel French Door Refrigerator
We have a 3-year old GE Profile side by side refrigerator/freezer. The vegetables and fruits are freezing in both crisper drawers. The refrigerator temp is set at 37 degrees. Thanks for your help
  • margaret_790 Jan 02, 2011
    As this refrigerator has been working properly until recently, and I don't think the freezing is a result of over-filling the compartments, I would like to look at other ideas as to why my food is freezing in those 2 compartments. The deli drawer and the rest of the refrigerator is working fine. The model number is: PSS26MSTE SS if that helps with the diagnosis. Thank you
    I will try your suggestions. Thank you!
  • GE Master
  • 5,370 Answers
The ventilations in the drawers are getting blocked.I will explain.When the unit starts,the freezer section starts cooling.When the freezer section gets cooled properly and reaches its regular temperature,then thermostat in the freezer section detects it and after this defrost procedure starts.In defrost procedure the fan in the freezer section starts running and the cool air from freezer section pass to the fridge section bu the ventilation drawers.And thus passes in all the sections.But in your case the cold air is passing to the vegetable and fruit section,but its not going to the other sections.The cold air is entering the section but its not going anywhere,just remaining there.So this parts are getting over cold.So in this case,either the defrost is not working or the coils are over frosted in the freezer section.And this causing the problem.But first try defrosting the blocked ventilation by manual defrost procedure.--------------
The defrost is not working or the evaporator coil in the inner section of freezer is got blocked by ice .
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.You can get the required parts from online sites like:--- www.repairclinic.com or from searspartsdirect online site.---------This will help. Thanks. Helpmech.
Posted on Jan 02, 2011
    Genius:
  • 1,456 Answers
Hello
Check the temperature of the crisper compartment using a refrigerator thermometer to ensure that is stays between 34 and 40 degrees Fahrenheit in order to maintain the food the longest.you can change between these temperatures to see if the freezing stops.
The best way to prevent foods from freezing inside the crisper drawer is by not filling it more than 3/4 full, which prevents air circulation. If freezing occurs, rearrange the food so that large items are equally dispersed among smaller items to create air gaps.
If freezing continues then you will need to check that your thermostat is working perfectly.
GE psc23ng...the veggie bin is freezing vegetables and temp. on fridge and freezer does stay put!!
GE Appliances Customer Phone Number Shortest Wait Best Support
GE Appliances Calls You Instead
Good Luck
THE FIX
Avoiding Frozen Lettuce
By TIM McKEOUGHPublished: March 18, 2009
Q. How can I keep produce from freezing in my refrigerator?
More Articles in This Series
Jason West, the marketing manager for refrigeration at General Electric. "Nobody really knows what the temperature of B is, or what the temperature of No. 5 is."One solution is a refrigerator thermometer. Oxo makes a handsome one with a round dial attached to a suction cup that can be installed easily on either interior side wall ($12.99 atoxo.com). Taylor makes a rectangular digital one that is installed the same way ($12.47 atamazon.com).
Once you have the thermometer, "put it in overnight and check it immediately in the morning, the first time you open the fridge," Ms. Reek said, because the temperature varies during the day as the door opens and closes.
The problem might be where you're storing fruits and vegetables, which are sensitive to cold air. Leafy vegetables are especially prone to freezing, Ms. Reek said, because of their high water content.
Although some newer refrigerators have separate cooling mechanisms for the main body and the freezer, most refrigerators cool by funneling air from the freezer into an opening near the top rear of the main compartment.
Fruits and vegetables should be kept away from this outlet, Ms. Reek said, or else "you're going to be blowing that very cold air right on the produce."
Both she and Mr. West recommended keeping produce in the crisper drawer, away from the circulating air.
"You don't want the moisture to transpire out of the product and make it limp," which can happen with produce on a shelf, Ms. Reek said.
If the crisper is full and some produce has to sit on a shelf, it's better to keep it at the front of the refrigerator, because cold air falls down along the back wall. Along with the area directly beneath the outlet, Mr. West said, "the back and bottom of the refrigerator tend to be the coldest spots."
Shirley O. Corriher, a biochemist and cookbook writer, suggests shaking off all the surface moisture from produce and sealing it in heavy zip-top freezer bags before putting it in the crisper drawer or on a shelf.
"Oxygen is a major villain, so to speak, in the deterioration of fruits and vegetables," said Mrs. Corriher, the author of "BakeWise: The Hows and Whys of Successful Baking" (Scribner, 2008) and "CookWise: The Secrets of Cooking Revealed" (William Morrow Cookbooks, 1997).
Lettuce leaves, in particular, benefit from being sealed in plastic, she said, and you should roll the bag "until you squeeze all the air out. That lettuce will keep for three weeks. It's just amazing."
Still, Ms. Reek said, "the objective of food is to eat it."
"If it's fresher, it's going to have higher vitamin content and be healthier for you," she said. "So it's really better not to plan to store food for ever and ever."
Feb 16, 2015 | GE Refrigerators
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
Jul 14, 2010 | GE Profile¿ Arctica® Energy...
Crisper is freezing
This is a bad damper and it would need to be replaced. Try turning the freezer warmer until you can get this fixed and move up your stuff from the drawers.
May 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Apr 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a GE profile side by side and the fruit vegetable drawers freeze what ever is in the them. The temparature in the refrigerator is 37 degrees F
If you cannot adjust the temperatures or close the air dampers on left side of the crisper contact me withe the model number. 38 degrees is perfect safe temperature for lower section. There are several styles of the Profile. That is why I asked for model number is to see exactly which style you have. For example PSS26MRSS would be what to look for. Sea Breeze
Feb 16, 2010 | GE Refrigerators
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Jan 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE PFS22SISSS Stainless Steel French Door Refrigerator Logo
252 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
