Question about Cameras
Samsung dvd vr-320 ec207 get this error code when trying to recored with a blank DVDR-
jaffa012001
  • 376 Answers
SOURCE: unlock codes for philips dvdr 3510
Make sure no disc is loaded
Press on the RC:
0 0 8 6 0 0 0
Done!
Posted on Sep 10, 2008
blueextc3221
  • 15935 Answers
SOURCE: what is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Posted on Jan 10, 2009
  • 6 Answers
SOURCE: samsung dvd-vr 357 remote code for comcast
The HD cable remote --> Code 21075
Posted on Feb 01, 2009
SOURCE: Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Hey New firmware available for this "Timer issue" from Samsung and it works for me.
New firmware version - 080610.
Just ring Samsung and find out. They can advise nearest service cnter to do this.
Posted on Feb 13, 2009
  • 107 Answers
SOURCE: my samsung vr 320 dvd recorded will not format dvd
after powering on your machine, hold both channel up and channel down buttons on the front of your player for approx 10-15 sec. The player will reboot and you should be fine. I had the exact same prob with mine
Posted on Apr 11, 2009
I'm getting an "unexpected error" while trying to
most likely its an incompatibility between the media and your drive. try another brand of disk.
Mar 23, 2011 | Samsung SES084 8X Slim External DVD Writer...
Samsung VR-320 discs will not read says no disc inserted
I have the same problem, but not with all cd, some cd i got the message, bij 2nd try the disk loads well.
I guess the laser of the machine is dirty, i clean the machine now and let you know how it goes
Jul 18, 2010 | Samsung DVD-VR320 DVD Recorder/VCR
My drv/vcr recorder wont record,i'v tried several dvd's and it wont read them it keeop saying it cant be recored on
Most dvd/VCR combo's dont record to DVD but record from the DVD to the VCR. If yours doesnt say DVDR DVDRW+ or DVDRW- then it doesnt write to DVD.
Apr 17, 2010 | Televison & Video
It won't recognise a blank dvd.......its says "The disc cannot be played....please check the disc" I HAVE A DVD VR 357
check the disc in your PC if this finds it as a blank dvd then possible play head error.
Use a DVD+/-RW and use Imageburn to full erase then try this one in the recorder this may work if not a possible motor failure on the spindle
Jan 17, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
I am trying to record to a blank dvd-r. I load a
If exact model is Samsung DVD-VR357, than it doesn't even has to recognise blank disc as your unit is DVD PLAYER with Video Casette Recorder.
See Specs. for your unit below:
Function Combination VCR Y Compatibility Playback Media DVD-R,DVD-RW,DVD+R,DVD+RW,CD-R/RW,CD,VHS, DVD-RAM Playback Formats MP3, WMA, JPEG, MPEG-4, DivX A/V Quality Progressive Scan Y HD Upconversion 720p/1080i Digital-to-Analog Converter 10-Bit/54MHz DTS Output Y Dolby Digital Surround Sound Y Connectivity HDMI CEC Y Convenience Child Protection Parental Control Physical Features Connectivity HDMI Output Y Component Video Output 1(Rear) S-Video Output 1(Rear) Composite Video Output 1(Rear) Coaxial Digital Audio Outputs 1(Rear) Optical Audio Output 1(Rear) Product Weight & Dimensions Dimension 16.9" x 3.1" x 11" Weight 8.8Lbs. Shipment Weight & Dimensions Dimension 20.2" x 7.1" x 15.1" Weight 12.1Lbs.
Closest model match for DVD recording unit would be DVD-VR375
Unfortunately you have player only and you won't be able to recor DVDs with it whatsoever.
Good luck
Jun 24, 2009 | Samsung DVD-VR357
Dvd player wont play movies recorded by my friends. what is the problem?
Not all DVD players can play DVDR or DVDRW discs (writable DVDs) these players are however very inexpensive. Usually the ones that say they will play windows media file will work, but not always. See if you can find one that says it will play DVDR or DVDRW discs.
Apr 13, 2009 | Bose Lifestyle 28 System
My samsung vr 320 dvd recorded will not format dvd disc"s when i follow the on screen instructions. it says error
Apr 11, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Samsung dvd recorder
Make sure you have finalised the disk, otherwise it won't play back on other players. Also there are two standards that you can use to record onto disks, video mode or VR mode. Video mode was the original standard but it wouldn't let you edit or add anything to the recording afterwards but it is more compatible with other players. VR mode allows you to edit the recording but is less compatible for playback on other players.
Mar 28, 2008 | Televison & Video
Samsung dvdr-120
try checking on the recording mode of the DVD. V recording mode produces more compatible DVD disc. Stay away from VR mode. You may refer to your manual.
Jul 26, 2007 | Samsung DVDR120 DVD Recorder
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
