Question about GE WPGT9350C Top Load Washer
Water drips in the tub
I have water dripping in the tub when a cycle is finsihed. The problem went away when I cut off the supply lines. What could the problem be?
  • GE Master
  • 2,651 Answers
A faulty inlet water valve on the machine itself, just not seating properly allowing water to flow after shutting off, turning off water inbetween washes a good temp fix as well as a good habit to get into
Posted on Jul 09, 2008
After wash cycle is finished I lift the tub lid and water is dripping into tub.
You may be looking at residual water dripping down from the rim. If the drip is located near where the water fills from, then you may have a water valve (could be either hot or cold side) that is not able to close completely. The valves are typically replaced, but sometimes cleaning can help for short term. Consult your user manual for removal / replacement instructions.
Aug 18, 2010 | Maytag Washing Machines
The water drips from the ice maker into the ice tub
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Jun 16, 2010 | U-Line 15R Compact Refrigerator
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
Water won't stop right away in door when glass pulled away
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Water continues to drip and fill tub after wash cycle completes
Your water inlet valve where the water supply hooks up to the washer is not sealing good.It can get sediment in it and cause this. Having a well for water supply can cause this more than water that has time to settle.
Sep 02, 2009 | Maytag PAV2300 Top Load Washer
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Whirlpool washing machine, extra large capacity Plus. Water drips from the top back of the washing tub into the spun-dry clothes after doing a load. Dripping water source is higher and slightly to the...
it sounds is if you have a possible crack in the water supply area. if the hoses are good, tight and dry, inspect the housing base they screw into.
Aug 16, 2008 | Washing Machines
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Open Questions:
GE WPGT9350C Top Load Washer Logo
189 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
