Question about Maytag Dishwasher
How do i get to the drain filter. the maytag does not empty. I have taken the line off and it drains but the pump does not push it to the disposal
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
their is no drain filter per say, you can get to the pump, at the base of the unit. you may also have a defective check valve.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Maytag dishwasher won't drain
Drainage problem of some sort is usually the cause. Could be blockage before your drain pump, in your drain pump, or in your drain hose. One possibility is that you just installed a garbage disposal and forgot to remove the "knock-out" plug for the dishwasher drain line. Another cause can be that you have not looped your dishwasher drainline under your sink and water from your sink is flowing back into you dishwasher. You must attach your dishwasher drain line under your sink so it is higher then your sink drain lines, creating a trap for your dishwasher. Your drain sump could be plugged, not letting the water get to your drain pump easily. This is caused by not getting loose or hard debris off your dishes before putting them in the unit. Also make sure your drain pump is getting the right voltage when it is supposed to.God bless youfa618d8b-d0fd-412a-b0d5-a88d44bf89d3.giffb1320dc-7bec-4cb0-98ed-c24cf54e5e3b.jpg
Apr 02, 2013 | Dishwashers
Water is not draining Maytag Jetclean
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 24, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
I have a Maytag MDB7100AWB that won't drain water after completed cycle
Hi
Thanks
Rylee
Dec 23, 2009 | Maytag Dishwashers
Our Maytag MDB7100AWS Dishwasher fails, inconsistently, to drain.
Hi
Thanks
Rylee
Dec 23, 2009 | Maytag MDB7100AWB Dishwasher
My Maytag dishwasher will not drain at the end of the cycle. However, if I start a new cycle the first thing it will do is drain. What should I check?
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 07, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwasher is not draining
Hi
Thanks
Rylee
Nov 04, 2009 | Maytag 24 in. MDBH955AW Built-in...
My Maytag dishwasher Model # MDB-3 will not drain. Please help. Thanks! Anna Giacobbe
Hi
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Quiet Series 100 Help - diswasher always has water in the bottom - doesn't fully drain. We took apart as far as we could down to the hole with the orange washer _ no obstruction. Put it back...
Hi
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
I have a Maytag dishwasher, model number DWU4910AAX. It is not draining. I suspect that it may be the pump, but I want to be sure. What should I do?
Hi
Thanks
Rylee
Sep 15, 2009 | Maytag Dishwashers
My dishwasher will not drain. I have taken it apart and cleaned the screens but it still will not drain. Any ideas? It is a Maytag MDB6000AWW
More than likely it is your food disposal. Remove your drain line from the disposal and clean and inspect it, then clean out where it connects in the disposal. This should allow it to drain, if not remove the drain from the bottom of the dishwasher and clean it out there. This should fix your problem.
Jun 21, 2009 | Maytag MDB6000 Dishwasher
Maytag Dishwasher Logo
209 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
