Home | Princeton Digital | VL1918 (Black) Monitor | Vl1918 it poweres on and...
Princeton Digital VL1918  Monitor
Problem for Princeton Digital VL1918 (Black) Monitor
Vl1918 it poweres on and shuts off.repeat
By mikehickerso on Jul 09, 2008
I have a VL 1918 Princeton monitor that is malfunctioning. The symptoms are: it powers on and off continuously with a 'clap sound right before turning off. I have taken it apart and there is a hissing noise coming from one of the transistors or one of the other things ,for which, I do not know the names.The hiss is hard to hear and track and could be normal. Yes I am shooting around but, I would really like to fix it. I also know it is an older monitor I guess but, I would still like to try. It also is not under warranty. I am fairly handy and have always wanted to figure something like this out. Any directives as intricate and seemingly advanced as they may be I will research and try to execute. Thank you very much Same monitor, same problem. What to do?
Clarification Request
Posted by Pestvic on Nov 08, 2008
so this will work with the vl1918? ill definately look into those caps. and if it works ill so happy :)
Same Problem
Feb 06, 2009
-   screen keeps flashing on and off with a noise each time it does it -   Guest
Nov 18, 2008
-   The monitor continues to cycle through on/off cycles. Stops after 20 minutes or so. Get a 'pop' sound when cycling off. -   The Pearl
Oct 20, 2008
-   I really hope people still read this... i have the same turn on. wait half a second. then turn off. repeatedly problem, but like NoResults said. i only have TWO (470uf 25v) capacitors on the power supply board, both looked kinda normal. not sure if they are bulged but i did notice some browning of the motherboard under where a square looking piece is, part # s5303-3602-01 LSE IOU218A 050 44s.PLEASE HELP if you need pictures of the capacitors to check if they are buldged or a pic of the browning please let me know a.s.a.p.-   Pestvic
Aug 26, 2008
-   I replaced the three 470mfd caps and the monitor is working like new. I had to pay $1.39 apiece for my caps at Radio Shack try buying components in Hawaii sometime.
Thanks TODDG
-   waikoloahand
Aug 19, 2008
-   Same exact symtons. I'm going to try replacing the caps as since the monitors been sitting by the trash to be taken out anyway I'll only be investing a little time.-   waikoloahand
Best Solution
posted on Nov 07, 2008
Very Helpful)
44Hink
Rank: Guru
Rating: 87%, 32 votes
I have 1500 Princeston monitors in my labs.
the 1700 series need a high rated cap. the company used Caps that could not react to constant on off abuse.
The 19s are about the same If you only have two caps.
the Larger cap is25V at 1000uf replace with a higher grade cap at 1000mF at 25Volts
the smaller of the two is 1000uF at 10 V
replaced again with a higher grade Cap vauled at 1000mF at 10Volts.
Belive me after 300 of these it's the caps. if they are buldging or not.
If you have a VL2018w the kind I just repaired today and one that i am using at this very moment.
It uses 4 caps on an a seperate inverter board. all four must be replaced. and use the good stuff.
all four are 1000mF at 10volts.I use Nichicon Capacitors only.About 3.50 for the average joe.
I get them for .45 but I buy like 1000 at a time.
I just repaired 4 1708's and will be repairing 11 of them tomorow.
Like I've said when they work, they work well and we keep ours on 24/7/365.
for the money I'd go with a Philips 17" or 19" they make them better than thier plasma TV's.
Hope this helped.
44Hink
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 27, 2009
Not Rated)
JimmyTea
Rank: Apprentice
Rating: 0%, 0 votes
First of all I'm not an electronics guy at all. I had a Philips 170S5B/27 monitor (3 actually for a triple monitor setup.) One was taking longer and longer to come on. So I was watching a eBay auction for another one for $70 ending in 90 min. Read on here about replacing the caps. Found 9, 470uf 25vt caps on the power bd with some bulging. (I think thats what it is) Radio Shack had 8, 470uf but 35vt ones. My Dad thought it would probably be ok to use them. (???) Replaced them and couldnt believe I got the monitor working like new 5 min before the auction ended! So I let it go. Only cost me $11. So thanks!!!
PS. Is this problem because of turning it on and off? I only use it a few times a week and for just a few hours (iRacing.com) so I figured I'd save energy and life by turning them off. Should I leave them on all the time?
Was this helpful?
Yes
No
Popular Solutions for Princeton Digital VL1918
Questions and Unsolved Problems for Princeton Digital VL1918
Do you recommend Princeton Digital VL1918 (Black) Monitor?
Answer
Answer
My Princeton monitor VL1918 keeps blinking on and off. What is wrong
Answer
I have a Princeton VL1918 Monitor with built in speakers. the volume is to low. how do I increase... (More)
Answer
It is a bit blurry and I want to know if there is a way to adjust the focus, or sharpness. None of... (More)
Answer
Princeton VL1918. Speakers stopped working. Check all connections. Other functionality is OK.
Answer
The Mac Mini that it's attached to is generating a proper video image, since I can mouse and click... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Princeton Digital VL1918 ...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
