Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
Takes to long to Preheat
Oven takes over 20 minutes to preheat to 400 degrees.
  • Anonymous Jul 22, 2008
    magic chef oven Model 3468 V V V takes 30 minutes to preheat to 350 degrees
  • colleenmilne Dec 10, 2008
    I have a Kenmore oven I just purchased and it is taking a long time to preheat. The salesperson told me all new ovens take that time now.
  • 148 Answers
The burner element iside the oven(the rod that glow,s orange) is burned out,even though it glows and the oven is warm,the element is worn out and has to be replaced,unplug the oven,shutt off gas supply to oven,pull off back cover youll see the rod coming thru each end of the rod will have 1 wire unplug the wire off the clip,go back to the inside the oven follow the rod to the back youll see 2 screws holding the rod unscrew and pull rod thru,easy job and elements arent exspensive,but make sure to unplug oven,and shut off gas
Posted on Jul 09, 2008
My Jenn Air JGS8850 takes over 10 minutes to preheat to, say, 400*. Is this normal?
In a word...Yes !
10 min. is actually a really great preheat time. I have many customers who would kill for that kind of preheat, most are between 15-20 minutes minimum to 350 degrees celcius, especially with the introduction of hidden bake elements in the last 10-15 years.
Hope that is helpful,
Good Luck :)
Oct 22, 2009 | Jenn-Air JGS8850 Gas Kitchen Range
Takes 20 minutes to preheat.
The unit seems to be working ok....usually the temp probe will reach temp in 5 minutes and it will beep....i sugg for cust to let sit for 15-20 mins for precise cooking.
Jun 11, 2009 | Kitchen Ranges
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
Preheat takes forever
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
Mar 01, 2009 | GE Ovens
Gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Frigidaire Ovens
sounds like the thermostat may be open and nees to be replaced. have a technician take a look at it.
Sep 07, 2008 | KitchenAid KGST307 Gas Kitchen Range
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
644 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
