Question about Frigidaire Refrigerators
We have a frigidaire mini fridge with the freezer on top. In the last week it has quit cooling properly. I've checked the coils for dust and they are clean. We haven't had it quite a year so if all else fails we will exchange it. Any suggestions?
Check for leaks on a freeon container
Posted on Sep 03, 2008
Frigidaire frs26lh5dso freezer works great, fridge side is warm.
make sure door to refrigerator is all the way up, so when it is closed it turns the cooling part on. I have to check mine all the time and screw it up if it's down, which is quite often. Mine is a side by side and I just make sure it's even with the top of refrigerator and even with the freezer door.
Jul 16, 2012 | Frigidaire Refrigerators
Frigidaire frs26r4 fan not working
So if your voltage changes with the fan plugged in, it would seem that your fan is blown and you need a replacement. This fan is needed to properly cool the top. You should be able to order the part directly from Frigidaire or there are many online sites to choose from. If you need help with this, let me know or if you have any other questions, just ask, otherwise, good luck
Jun 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
It is actually FRT21INLHW4, but i can find no info...freezer not cold enough and fridge last week froze some food...also seem to run alot! help!
The cooling coils are normally located around the freezer with the refrigerator being cooled via cold air circulating from the freezer to the refrigerator. If that concealed fan has failed, the mere fact that cold air falls might explain why the lower compartment is getting the hog's share of the cooling.
You should be able to see vents in the rear of the fridge; hold your hand (wet might be better) in front of those vents. You should be able to feel a flow of air into the fridge. If you don't, the fan may have failed.
Try Sears parts section to see if your unit is listed; they often have repair parts for many brands and models, and even more important, an illustration of your model which could guide you on how to access the fan for replacement.
Another possibility is the failure of the defrost timer that controls a heating coil also located near the freezer. If your defrost heater is staying on because the timer has failed, it could cause the situation you have. The timer is often located behind the grill at the bottom of the unit. Some of them have a **** to turn the timer mechanism manually. You can mark the protruding shaft position with a piece of tape or white-out to monitor if it is still running at all.
With the grill removed, try to remove as much of the dust bunnies from the coils as possible since this prevents the lower fan from getting air onto the coils to disperse the heat from the coils.
Oct 08, 2009 | Frigidaire FRT21H8 Top Freezer...
Freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Aug 02, 2009 | Magic Chef CTB1821AR Top Freezer...
Refrigerators Logo
552 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
