Question about GE Dryers
Dryer drum does not spin - GE Dryers
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you either have a broken belt, or if you don't hear air blowing out the vent, your motor can be defective.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Dryer will only spin with small load
You need to replace the belt that will solve all your problems.
Oct 17, 2012 | Dryers
When pushing the start button dryer hums but does not spin. when u release start button dryer shuts off
Sounds like a bad motor. Check to make sure the drum isn't stuck, if you can spin the drum put some tape on the door switch and press the start button while you spin the drum. If the drum continues to rotate, you have a bad motor.
Mar 10, 2011 | Maytag Washing Machines
Dryer is getting very noisy. Does this mean there is a problem ?
The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Screeching noises are not a good sign and sometimes its a sign that you drum is slowly cutting into the sides of your dryer which could permanently put your dryer out of use if its continues.i think i will work out
Dec 16, 2010 | GE Dryers
My dryer won't turn. The motor runs when you push start but the drum doesn't turn. I can turn it by hand and it will run.
- The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
- The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
- The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
- Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Dec 15, 2010 | Dryers
The dryer does not spin, the motor runs but the drum doesn't spin
The dryer either spins because of belts/ropes or because the motor directly contacts the dryer drum. I would tip the dryer so I could inspect the drum drive mechanism(s). Make sure you don't have a belt that broke or slipped or that a drive wheel locked up.
Mar 24, 2010 | Estate TGDS840JQ Gas Dryer
Drum will not spin. The belt is not broken but is hanging lose
If the motor is working...Shut off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Sometimes the motors get dead zones in them and this will help move it out of the dead zone
It could also be the drum rollers that need lubrication or replacement, if they are not rotating it would not allow the drum to spin.
I hope this helps
Oct 02, 2009 | Kenmore 73952 Gas Dryer
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryers Logo
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
