Question about Samsung RS2630SH Side by Side Refrigerator
RS254SH Door handle problem
I have a samsung model RS2545SH and its bottom part of plastic molding which is part of door handle is becoming loose. Its couple of snap in hoocks came out of its holes/housing. Can you help me how to put those snap into the holes or remove this piece altogether? Thanking oyu in anticipation.
SOURCE: SAmsung Service Manual
I have a Samsung RS2530BWP Side by Side also. You cannot control the temperature with the settings on the outside of the door. The fridge side stays about 40-42 and the freezer stays well below 0. Can I get a copy of the manual or find out how to buy one. Thank you,
Posted on Apr 14, 2008
  • 22 Answers
SOURCE: Samsung Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Posted on Nov 13, 2008
SOURCE: Door Removal
If you don't have the manual, go to Samsung's website and download the manual. It explains how to remove and adjust the doors and bottom drawer.
Posted on Jul 25, 2009
  • 59 Answers
SOURCE: Samsung RL36SBMS Bottom Freezer problem
Posted on Aug 19, 2009
SOURCE: Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Posted on Apr 15, 2010
Samsung French door fridge freezer handle came loose. The ***** on the right side fell into the back of the handle attachment so it won't go flush with the fridge.
Hello Marilyn;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on a label on the inside liner of your fresh food section.
Usually the door handles are held on in one of two ways.
1.) Inspect the sides of the door handles. Are there small allen wrench screws - tighten them.
2.) Ok, no screws on the side. There are mounting brackets screwed onto the door. At times the screws become loose. Use a little muscle and pull the handle up hard to release from the bracket. Tighten the screws on the bracket to the door. Position the handle back on the bracket and pull the handle down hard until secure.
Mar 03, 2016 | Samsung Refrigerators
How do I tighten door handle on whirlpool fridge how do I get to the screws model gb2fhdwq02
Hello Tim;
You have one of two door attachments:
1.) There are two 3/32" K set screws (Allen Head) at the top and bottom of each handle. Back off these screws until the handle comes off. The is a stud with a screw - tighten and reattach the handle.
2.) There are two brackets mounted to each refrigerator door. One at the top and one at the bottom. At the top of each bracket is a oversize hole. On the back of the handle there are two screws. These screws fit into the oversize hole. Then you push down into a slot to secure the handle. To remove the handle you push up on the handle until the door handle screws are into the oversize holes.
The screws on the door bracket often become loose. Tighten these screws. Sometimes the mounting screws on the door handle become loose as well.
Be careful, if you tighten everything up too much you will not be able to remount the door handle. Adjust the screws for a tight fix
Oct 31, 2014 | Refrigerators
Lg Gn422s loose handle, I can't see a screw to remove the plastic handle at all
You will need to remove the door seal and expose the screws that hold on the inside plastic door trim
remove the door trim to get to the handle screws
Apr 15, 2014 | Refrigerators
Have a tube w/rubber end hanging down in ice maker. Also a molded styrofoam w/ plastic loose in ice bin on model#253.70313211 French door bottom freezer. Wher does this belong and how do I fix it.
It fell of the bottom of your ice maker put your model number into and you can find a pic or video that shows you how to put it back together
Mar 02, 2014 | Kenmore Bottom Freezer French Door...
Remove door panel
Trim and molding remove tool and a phillips screw driver
Drivers Side
Door trim panel and water shield (top where window is)
Plastic panel around door handle. snaps out
1 screw upper front extension assembly (plastic triangle)
2 screws located lower bottom left (drivers side) and door trim panel
Use remove tool to push out retaining 'C' clip behind door handle
Grasp panel where opening are and pull up and out gently
Now disconnect wire harness
May 07, 2013 | 1991 Ford Thunderbird
Loose door handles.
There was a plastic card the size of a credit card that came with the refigerator that helps release the handles. If you don have this you can use any stiff plastic card ie: blockbuster card, store card etc...
Pull the handle away from you while inserting the card in the top or bottom of the handle based on your model. I believe the Admiral model LSD2615HEB required the card be inserted 11/16 of an inch. This should release the handle. Once released there are 4 hex screws located on the handle that may require tightening.
To reinstall: Match the hardware up just above the final location and then slide down, this should lock the handle back into place.
Feb 24, 2009 | Admiral 26 cu. ft. Side-By-Side...
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Dec 22, 2007 | Refrigerators
Loose freezer door handle
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Jul 04, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Samsung RS2630SH Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
