Question about Keurig B50 Coffee Maker
We have had our Keurig Limited Edition B 66 Keurig brewer for almost a year. Worked fine until now. The Power will not turn on. We tried plugging other things into the same outlet & their is power; so it isn't the outlet. We love the unit but I would think it should last longer than a year. We only use the unit in the morning for (2) cups of coffee as there is only one person who drinks coffee; so it wasn't overused. Is the brewer burned out? What can we try. HELP!!!.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
It sounds like you unit has a major malfunction. and they do break
Keurig does not make repair's or carries replacement parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Testimonial: "Thanks for the immediate response. I will contact Customer Service at the telephone no. you gave me. Hope I get a good response from them. "
  • Barrett Palumbo
    Barrett Palumbo Jan 02, 2011
    you will, they are good about it
I have a Keurig 2.0 when you plug it in the power button comes on, on the lcd screen but when you touch the power button nothing happens. It won't turn on. Any suggestions. Thank you.
Found the below from this site: http://coffeestylish.com/keurig-problems/
Keurig 2.0 won't turn on
To turn on your Keurig 2.0 plug in the brewer, then press and hold the power button (the power icon will appear in the bottom right corner of the touchscreen). You should see a welcome! note. If it doesn't turn on you can do few things:
Check to make sure that the brewer is plugged securely.
Unplug and plug in the brewer.
Plug the brewer into a different outlet.
As a last step, Keurig even recommends resetting your home's circuit breaker just in case.
If nothing works, then you should definitely call Keurig customer service.
Jan 24, 2016 | Computers & Internet
Tip
BURNZY.....YOU ARE A GOD SEND!! After calling the Keurig Service Center about my...
Symptom: keurig B100 coffee maker not brewing. If your brewer sounds like it should be brewing but little or no coffee comes out, the problem may be a simple malfunctioning check valve, located on the right hand side of the unit under the plastic cover. If the check valve is clogged or fails, water from the tank leaks into the air pump (located just below the valve) disabling the pump. This happened to my brewer two days ago. I have had this unit for about four years and never had a problem. When I called tech support at Keurig they said "it sounds like the pump is shot", but there was nothing they could do and they would not repair it. Instead of the throwing out my $300 coffee maker I figured I would try to fix it myself. After 3 hours of tinkering, I found and fixed the problem, so I am passing on the tip. Since 2.5 of those hours were spent diagnosing the problem, the fix itself is pretty simple. The pump that pushes the water out of the tank located on the right hand side of the unit (I included a photo) has a check valve just above it. On my unit the check valve failed allowing water to enter the top chamber of the pump disabling it. The pump was not damaged it just cannot operate correctly with water in it. Here is the Fix: Disconnect the check valve and make sure it is operating correctly. Mine was clogged with a small amount of mineral deposits, which was cured by a half hour in a glass of vinegar, and a good rinse. Then disconnect the tubing from the top of the pump and run the unit to allowing the water to escape the pump. Make sure there is no water left in any of the tubing between the pump and the check valve, even the smallest amount will disable the pump again. Reconnect everything and it should work. Hope this was helpful. Erik
on Dec 13, 2007 | Keurig B100 Coffee Maker
My wife bought one of these coffee makers about one year ago. It worked fine until Wednesday. She turned it on and it popped. Then we smelled an odor like something electrical was burning. Of course, the...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 24, 2011 | Keurig Elite B40 Coffee Maker
One day the brewer worked fine the next there was no power. Tried unpluging it and waiting then plugged it back still nothing. Not sure what the next step is. Does the machine have a rest on it? What are...
heatman101
Aug 27, 2011 | Keurig Elite B40 Coffee Maker
Will not turn on. Worked fine this morning, came home and power light was out unplugged unit and then plugged back in, nothing. Any helpful info for the power issue?
heatman101
Aug 01, 2011 | Keurig Elite B40 Coffee Maker
I've had the Keurig B60 about 6 months. It has worked fine until yesterday, when the power went out and will not turn back on. I checked the breaker and switched outlets, to no avail. The power just...
heatman101
Jun 25, 2011 | Keurig B60 Coffee Maker
Keurig Special edition stopped brewing
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Dec 25, 2010 | Keurig Special Edition B60 Coffee Maker
My Keurig platinum B70 will not pump water through the system. It says "Ready to Brew",I push the brew button, it says "Brewing", but nothing happens. It also defaults to the largest cup size, and will not...
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Dec 01, 2009 | Keurig Platinum B70 Coffee Maker
Keurig B50 Coffee Maker Logo
1,029 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
