Question about Panasonic DMRES15 DVD Recorder
DVDrecorder dmres15. I can't play a dvd it keeps saying fault U61 and that it is carrying out its recovery process. I've bought a cleaning disc but it wont work.
    Problem Solver:
  • 4 Answers
Hello.
Since I haven't seen any other responses, I thought I'd share my experiences with you. I'm sorry, this is only a comment, and not a solution.
I had the same issue with my DMR-ES15 over 2 years ago, for which I was never able to find a solution. So, I sent it off to Panasonic for their 'out of warrantee' repair, for a hefty price. (Could have bought new, but really liked the features of the ES15.) So, got it back from Panasonic, and it worked well for another 2 years. (Their 'out of warrantee' repair warrantee was only 90 days. This always seems to be a gamble.) Unfortunately, it died it's second death a few weeks ago. Since '2 lives' are probably more than to be expected for this kind of disposable electronic device, I won't pursue another repair. (By the way, it is increasingly difficult to find a stand-alone DVD recorder (with no VCR) with a tuner in it.)
Sorry it's not better news, but I'll follow-up if I find any additional info.
Posted on Feb 05, 2011
Dvd recorder comes up with fault u61 what is that fault and how do i fix it.as it wont do anything till its fixed
I have the same problem. System displays 00000, then goes to 12:00am, then flashes U61...please help
Jun 20, 2010 | Panasonic DMRES15 DVD Recorder
U 61 code, how do i fix this
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
These seems to be for all similar ranges.
Dec 05, 2009 | Panasonic DMRES15 DVD Recorder
I load up my Panasonic DVD recorder and it has built in freeview as well. Every time i load up my box it comes with up with U61 error and the machine makes a funny noise while trying to load the DVD drive...
The unit is carrying out the recovery process without a disc in the tray. The unit detected an error while recording or playing without a disc in the tray. The recovery process restores the unit to normal operation. Have the unit power cord unplug for about 5 minutes, then reconnect. If issue still exist have unit service.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
PANASONIC DMR-ES35V have error code U61
From User guide:
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
U61 error won't go away
I've solved my problem - thanks to a suggestion on another site. Apparently the machine is sensitive to the type of disc when it has a problem - I inserted an identical make and type of disc (RW in my case) and it then completed its 'restore to normal operation' and the error msg went away.
Also suggested but didn't work in my case was opening the flap on the front, and with the machine OFF, press and hold STOP and Channel UP.
Hope this helps
Judith
Sep 28, 2008 | Panasonic DMRES15 DVD Recorder
Error code U61 on a panasonic DMR-ES35v When I turn it on it says "Please Wait" end the code U61 occurs after som while.
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Aug 30, 2008 | Panasonic DMR-ES35VS
Panasonic DVD SC-RT70 whilst recording disc stopped and shows error code U61. Recovery process did not work message keeps repeating
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
Jun 16, 2008 | Panasonic Televison & Video
U61 on panasonic dmr es15
For U61 errors:
Turn unit off
flip down front a/v input panel
simultaneously press the channel up and stop buttons for at least 10 seconds.
Jan 29, 2008 | Panasonic DMR-ES10 DVD Recorder
Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMRES15 DVD Recorder Logo
637 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
